sizing a bush hog
/ sizing a bush hog #1
southerndeere
Do u guys think a 7' heavy duty bush hog is to much for an 85 hp tractor. 75 pto
/ sizing a bush hog #2
What tractor? What outside rear tire width? With or without FEL counterbalance? How heavy a Bush Hog?
/ sizing a bush hog
Its a t4.85 new holland. It does have a fel. I cznt remember the model on the e mower but it is the heavy duty bush hog brand. An it has 18 tires set on 36 inch row spacing. Not sure of exact outside width
/ sizing a bush hog #5
You could pull / lift an 8' Bush Hog 3008 Dual GB cutter. We have one on a 96 HP NH just to get between trees.
See our Avitar.
/ sizing a bush hog #6
It will, but I'd rather have a dual spindle 8' cutter than a 7' single.
I used to run a 10' cutter with our old 2355, 56 PTO hp.
/ sizing a bush hog #7
I use a 7 foot deck on my LS P7010 and it hardly knows it is back there unless I hit really high wire grass. My deck is made from 1/4" plate all around and weighs more than 1500 pound which makes it a good counter weight for my FEL. A 7 foot is about all I can use to get between the trees where I mow otherwise, I could likely pull a 15 foot batwing but maybe not as fast as I pull the 7 foot. Weeds cut much easier than tall grass so much depends on what you are mowing but with your tractor and a 7 foot mower, you could be mowing down small trees with no problem of power, 5 HP per foot is generally accepted formula for PTO power.
/ sizing a bush hog #8
It will, but I'd rather have a dual spindle 8' cutter than a 7' single. I used to run a 10' cutter with our old 2355, 56 PTO hp.
BH 3008 is a dual spindle?
/ sizing a bush hog
Does multi spindle use less hp?
/ sizing a bush hog #11
a 7ft heavy duty cutter an easily be pulled by an 85hp tractor.we pull a 14ft ridgid brushhogg shredder with a jx80 an 7040 kubota with no probs.
/ sizing a bush hog
Decided to go with a 7 ft gr series rhino. Its supposdly good for up to 4 1/2 inch brush. It will never see that around my farm. But the deal they are giving me I couldn't resist. I can't wait to getthe combo on the farm to see how its gonna run.
Cat CB24B (A60462)
Cat CB24B (A60462)
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2022 EZ-GO ELITE...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
