Single remote valve
/ Single remote valve #1
jdwb
Union Springs, Alabama
Mahindra 5530
I am thinking about buying a Mahindra 5530 4 WD with front end loader and am told I needed a single remote valve. Is this for the back hydraulics to use with a hay cutter, rake and/or hay baler?
/ Single remote valve #2
/ Single remote valve #3
When you are working with a little bigger tractor as in the 5530, there are a lot more of the implements that have or can have hydraulics to do some of the adjustments or activation of the implement. I have 3 remotes on two of my tractors and I really need 4 on each one of them. If you do go with some rear remotes and do not go the OEM route, then I too would be installing a 4 valve setup. I believe that with the 5530, Mahindra only offers 2 remotes at the most and pretty pricey. The OEM setup is usually a little nicer & cleaner looking than the aftermarket stuff, but is quite a bit more $$$$. Anyway that you look at it though, it would be nice to have the remote there if you need it. ;)
2014 FEATHERLITE GOOSENECK LIVESTOCK TRAILER (A63291)
2014 FEATHERLITE...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
KUBOTA M4700 TRACTOR (A64280)
KUBOTA M4700...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
