Simplicity Zero Turn Hydro Change
/ Simplicity Zero Turn Hydro Change #1
iplumb
Mason MI.
B2920
I have a 2004 Simplicity 20hp/50" zero turn and I need to service the Hydro drive sysytem this year I think? Anyway I'm looking for a service wright up on this does anybody know of onw :thumbsup: I don't even know what hydro oil is required? THANKS
/ Simplicity Zero Turn Hydro Change #2
Most of these units will have HydroGear, Kanzaki, or Parker pumps and similar wheel motors. The newer hydro units specify 10-50 Mobil 1 synthetic oil or similar.
Check the pump type and model # and then that Mfg. web site for suggested oils. Most of these units have a resivoir with a cap and usually the oil type is on that tank or cap.
One more thing, in order to get all the oil out to do a full replacement you may need to drain the pump/motors too, then getting oil back through all these lines you should leave the lowest point(s) open while adding oil then tightening that connection. You want to make sure you get all the lines refilled before running the pumps. (you could pull the plugs and use the starter to charge the pumps before running full tilt as one option).
If you dont like the sounds of this procedure then have a dealer do it - may be $ well spent.
Thanks, Anybody else?
WOW! My wife just found my manual :thumbsup: it states to change only the filter @ 250 hrs. No mention of the oil. Must be life time:confused2: not sure how I feel about that.
UNUSED FUTURE TB72 TREE BOOM (A65055)
UNUSED FUTURE TB72...
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
More info coming soon. (A64557)
More info coming...
3143 (A63117)
3143 (A63117)
