Simplicity 9518 rebuild
/ Simplicity 9518 rebuild
Well, havent been able to work on the tractor lately since ive been at my moms. Next weekend im gonna see if i can start it up.
/ Simplicity 9518 rebuild #22
GOOD LUCK with it Jake !!
CHEERS!
. . tug
/ Simplicity 9518 rebuild #23
I found out it is a fuel bowl with the part number as simplicity 2098414. I need help finding one to use. I tryed napa's site but it wouldnt respond. here is the diagram. Parts and Diagrams for Simplicity 2097353 - 9518, Compact Diesel Tractor, Turf Tires
72101342 (cup) is the part number you should be referencing. I just purchased one for my Simplicity 9518 from my local Massey Ferguson dealer. Was less than $10. Mine was gummed up with varnish and crap from running biodiesel. You can search for parts under the Allis Chalmers model 5015. Go to (w/ Internet Explorer; Guest account doesn't work with Firefox) : AGCO | Parts click on agcopartsbook.com link and sign in under guest user. You can view all the parts books for your tractor under Allis model 5015. Napa sells many common service parts for these tractors under Allis Chalmers 5015.
FIL 1210 hydraulic;FRAM PH4386 oil; FIL 3282 Fuel Filter. Try to reuse your glowplugs; they can only be purchased through AGCO/Massey and they are $70 each. Special size NGK plugs. Called NGK to find alternate dealers but none exist.
Make sure you put motor oil in your injector pump. Owners manual calls for 7 ounces; excess will spill into crankcase.
I have the owner's and parts manual that I downloaded for free from the Simplicity website under model 9518 in PDF format but they are too large to attach to TBN posts. 9.55 MB zipped.
I've been using amsoil SAE 30/10-30 synthetic in my 5015 because it can be used all year especially in New England winters. No need to go to 10 weight or 20-20W as indicated in owner's manual. AMSOIL - Synthetic 10W-30/SAE 30 Heavy Duty Diesel Oil (ACD)
Hey thanks, that is very helpful. It is also nice to know there is someone else outthere with a 9518. One question, does yours have R3 or R1 tires on it? 4wd?
/ Simplicity 9518 rebuild #25
I have the Agriculture deep lug tires on front and back. Back tires have the 8x18 rims loaded. Mine is 4WD.
Thats cool. Still been waiting to get mine started. I have high hopes for this tractor and when I get it running and driving around, I want to replace the R3 tires with R4s for better traction. I would get R1s but the rims would better fit an R4. That and it would look really cool with R4s anyway. :D Hopefully going to start it this spring. It will be nice to have 2 tractors to play with.
Got to work on my tractor this weekend. First thing i did was rotate the muffler upward, to make it look more like a tractor. It was sideways since the previous owner probably used it to mow under trees. Then I removed the belly mower brackets and part of the assembly on the front. Removing these made it look even more like a tractor than a lawn mower. Then I checked out the bearing for the PTO. It was perfectly fine. I straitend out the plate that attaches to the fenders and tranny case with my Dad's 3720. I also found an area that looks like i can make a plate that goes up, out, and up again to attach to the ROPS system I got off the neighbor's burned tractor. From the looks of it, I may be able to start my simplicity soon. Im having my dad get some ethur, a new starter, and a battery so we can try and start it up. once its running, then I can work on the cosmetics.
Tried to start up my simplicity last night. I'm thinking that since the fuel lines are plugged and currently off the tractor, that the engine wasn't getting enough Diesel to start the tractor. My dad got a battery for my tractor but it was too wide to fit on my tractor, so he is going to order a new one. It really wanted to start up last night so today we are going to blow out the lines with the air compressor to see if we can start it up. I also removed some more parts for the MMM that was on it long ago. On the Oil filter, I also noticed that it hasn't been changed since 1994! :shocked: Pictures coming soon.
/ Simplicity 9518 rebuild #29
I'm looking forward to the pics and hope it starts right up for you:thumbsup:
Got the lines blown out. Tried to start up the tractor, but it wouldnt fire. Sprayed ethur in it and everything, but it didnt fire. My Dad is going to hire a Diesel Mechanic to look at it and determine the problem so we can fix it. So in the mean time, Ive been working on the ROPS system for the tractor. I pulled the tractor outside and used the 3720 to hold up the ROPS so I could measure some things. I think the tractor looked pretty good with the ROPS. I temporarly put the left fender back on and the distance between the posts for the ROPS was perfect. Today, my grandpa and I went out in the shop and made a bracket that attaches to the tranny for the ROPS rather than sitting on the fenders. It is made with 1/4 steel. It attaches behind the top link for the 3 point and goes up, through the back plate, to the ROPS mount. I cant wait to go back to my Dad's to install my ROPS! in return for all the help my dad has given me, I greased his tractor and lawn mower yesterday morning. The tractor was pretty dry. i also greased the steering on the Simplicity. Also, I removed some more mower stuff from the tractor. Now I have a small pile of Mower assembly for the tractor that i have no use for. It was miserable removing all of it so I dont plan on ever putting it back on.
I got to install my ROPS last night. My grandpa made me some brackets that attach to the tranny case to the ROPS. I did have to bore out 1 of the holes but otherwise it worked perfect. It is made of 1/4 inch steel. In the end, my Simplicity looked pretty good. The bottom of the ROPS are a few inches above the fender so i would like to somehow attach them together without lowering the ROPS.
Well, after trying to start my simplicity this weekend, I finally found out why it wouldnt start. My fuel pump was not providing the engine with diesel which is why it wont start or run. I know that fuel pumps are rather dificult to rebuild so we brought it to NewHolland this morning to have a certified mechanic fix it. We loaded it on the trailer by wraping a chain from the bumper of the tractor to the 3 point on the Deere. We jack knifed the trailer so the chain wouldnt hit the truck. Worked pretty well. When we got it there, I found out that one of the mechanics there used to work for simplicity so he knows my tractor inside and out. So this week, my simplicity shall be running once again for the first time in 15 years! Also, i finally got a new seat for it last night so now i can throw out the old one and be comfortable for seat time. Cant wait to bring it home!
Just found out that the new pump will cost $1000 plus labor. Is it worth replacing? I have to sell this tractor so I can upgrade to a larger one. What do I do?
/ Simplicity 9518 rebuild #34
How much did you pay for the tractor to start with?
How much $$ total will you have in it (including the $1,000 fuel pump) when you are done repairing it?
How much can you sell it for after the repairs?
Answer these three questions and it will make your decision a little easier. For instance, if you paid nothing for the tractor and it costs you $1,500 to get it into saleable condition, you had better be able to a couple grand selling it. If not it is just robbing money from your next tractor purchase.
Good luck
Mark
$800 in it so far. Got it for $300. Gonna try and sell it for $1500 obo as a project since I'd only loose $$$ if i replaced the fuel pump. The total for just the fuel pump and labor would be $1400. I could put that $$$$ into a bigger tractor.
/ Simplicity 9518 rebuild #36
Exactly, Now if you fixed it and could sell it for $2500 with the new fuel pump it may be worth it. Just make sure you are not going to lose money on the deal.
I guess sinced i dont have enough $$$$ lying around and not the guarantee that the fuel pump is the only thing broken it makes me think I should use the $$$$ on a bigger tractor. I would only be ahead a few hundred $$$ if I fixed the fuel pump and would loose my savings of $800. So I guess i would loose out on the deal.
/ Simplicity 9518 rebuild #38
Sounds like you've got a pretty good grasp of the situation. That's what I would do too.
Mark
/ Simplicity 9518 rebuild #39
Just an idea here but I never bought a pump from a dealer, I always had em rebuilt by a local shop that specializes in such things, have it rebuilt. I dont know what the going rate is now but I dont ever remember a rebuild being more than 500.
I would have the pump rebuilt but most everything on it is bad. I was on ebay last night and found a Massey 1010 (same as 9518) that is being parted out. if i can get a used pump for a lower price i can alternatly save $$$ and sell the tractor for more since it would be in working condition.
