Simple WOOD STOVE Build
/ Simple WOOD STOVE Build #1
DIRTROAD
Platinum Member
SOUTH CAROLINA
MF231, MF240, CAT D4K2
I wanted to build a larger woodstove for my shop and keep it as simple as possible.
I started with an insert that was in my basement fireplace and was very inadequate and inefficient. I cut the entire face plate off of the insert and, after cleaning it up, I welded it to a piece of 26"x1/2" pipe that I made 32" long. Doing it this way I didn't have to make any custom doors.
After that, I just closed in the other end of the pipe with an old piece of checker plate that I had laying around and added an exhaust. I also put reinforcements on the inside of the back wall of the stove to prevent warping.
Then I went back and trimmed the excess from the front face plate to make it round like the rest of the stove. I started to leave it square, but I figured the extra would just get in my way in the shop.
I already had all the materials except for the exhaust pipe, which I gave $10 for. I roughly figured my total cost of this build to be around $75. That covers the torch gas, welding rods, grinder discs, and that exhaust pipe that I had to purchase.
The pipe itself weighs 103 pounds per foot, so I estimate the weight of the entire stove to be around 400 pounds.
I just lit the first fire in it and it seems to be working excellent.
Here's a few more pics. I love the large size because I can throw whole logs in without having to split them (once a good fire and bed of coals is established). The round design seems to be working very well also. It feels like it is putting out an extreme amount of heat. It seems to be drawing excellent also.
/ Simple WOOD STOVE Build #3
Nice job.
How much distance between it and concrete floor ?, looks close, no worries about getting to hot and cracking ?
/ Simple WOOD STOVE Build #4
Good job, looks like it makes a lot of heat.
There is only 1" between the extreme bottom of the stove and the floor. I could put my hands on the floor a while ago and it wasn't too hot. It seems like the round design is forcing the heat to rise up and since there isn't a flat bottom to trap the heat it's not too hot. I've only had a fire going since about 3:30 though. I'm sure it will get warmer, but I poured the floor 6" thick so I think it should be OK.
/ Simple WOOD STOVE Build #6
I like it! Reminds me of one I built years ago by sliding a water heater shell into a 55 gallon barrel and using a barrel stove kit for door and exhaust. I put a firebrick baffle in it and it did great. Used it for many years. Yours has a lot more fit and finish! :thumbsup:
/ Simple WOOD STOVE Build #7
Good job DIRT.
Aluminum foil or bright sheet metal under it will alleviate any floor heat problems you may encounter.
/ Simple WOOD STOVE Build #8
Nice job.
Doesn't heat rise ??
The floor around my stove in the garage (shop) doesn't get hot even when fire wide open and roaring to heat metal so I wouldn't worry:)
/ Simple WOOD STOVE Build #9
View attachment 246468View attachment 246469
That looks like it will get very hot, nice job
Is the stove pipe outside and are you worried that it may not draw in extreme cold conditions.
Just a thought:)
/ Simple WOOD STOVE Build #10
Man, that thing looks like a BTU generating monster! Good Job
/ Simple WOOD STOVE Build #11
Good Afternoon DIRTROAD,
Wow that was a great job ! You hit a homerun with the idea of welding those doors onto that extra heavy duty pipe !!!
My neighbor did something very similiar, but he fabbed his own doors, not nearly nice as your setup, but it works well enough. He also had that heavy duty pipe, so Im sure that will never burn through, plus he lined it with fire brick...
He did one thing that I liked though, he made some hevy duty legs out of 2" pipe, and raised the stove up about 3 1/2' so that he doesnt have to bend over to tend the fire, and it makes it easier for adding wood also !
Very nice project, let us know how it works out for you... :)
/ Simple WOOD STOVE Build #12
What a great looking stove!!!An its a sir tight!Should give you years of service. I like the idea being able to toss in big stuff.
Army Grunt
YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO35-5...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
