Simple but handy
/ Simple but handy #1
PHPaul
Platinum Member
Downeast Maine
Kubota B2650 with cab, Pasquali 986
The sway bars for the lower arms on the 3 point hitch on my B2650 use a pin with a hairpin clip on the bottom for the adjustment.
The hairpin is tough to see and hard to handle with my arthritic old hands so I put a keychain ring on them to make them easier to get hold of. I was a little worried they might snag and get pulled off, but so far so good.
/ Simple but handy #2
I always Hated those type pin / clips but now with Your AWESOME remedy , I can stop changing those type out or swapping them with others I have .
Kudo's !!!! Super Idea !! :thumbsup:
Fred H.
/ Simple but handy #3
I swapped for larger pins from TSC. Those little ones are a pain to handle, I hate them.
/ Simple but handy #4
I use a loop of soft iron wire for the same purpose. I suppose galvanized wire wouldn't rust, but the soft iron seems to out last my remembering when I last put it on ;-)
/ Simple but handy #5
Good idea Paul. I spend most of my time when using them, looking for them in the grass, gravel or dirt as they slip out of my hand.
/ Simple but handy #6
Good idea Paul.
My first Kubota used them. I quit using them because they were so hard to keep track of. Never had a pin come out, but maybe I was lucky!!!! :)
/ Simple but handy #8
All of my current tractors have pinned sway bars. None have a latching pin. All just sit in the holes and are happy. All have chains on them in case they get loose so I won't lose them. I've never had one escape. :)
/ Simple but handy #9
I use these cotter rings instead of hair pins. Easier for me to handle and can't be yanked out by brush.
/ Simple but handy #11
I've converted all pin-on stuff to these
Zinc Plated Lynch Pins 3/16
I like them 'cause they're "glove friendly" even when they get a bit rusty. Can't STAND the "bobby pin" type... Steve
/ Simple but handy #12
Like ovrszd, I quit using those pains (pins) after the first time I took them out to adjust the sway. Been 3 years now, and I have not had one come out yet. The 2 original ones are out there in the grass somewhere, never to be seen or heard from again.
/ Simple but handy #13
Until some futuristic civilization finds them and spends a Gazillion Dollars trying to figure out what ancient civilization used them and what for??? :D
/ Simple but handy #14
My JD has horizontal holes in the sway bars so I found some old clevis's that will just fit over the bar. The clevis pins have been replaced by the appropriate size bolts that get tightened by my metric adjustable wrench. These seldom have to move all summer as I can just pull the pins on the axle when I remove the whole unit (counterweights, receiver, winch, etc).
Most times I back under the woodshed beam and lower the assembly onto a chain over the beam. This lets things "hang loose" so all the pins can be pulled or replaced with little or no tension on them...
I wish I had the newer sway bars with the vertical holes..
Rooster (A64557)
Rooster (A64557)
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
PALLET OF METAL STOVE PIPES (A64278)
PALLET OF METAL...
2024 HITACHI ZW95-6C WHEEL LOADER (A65053)
2024 HITACHI...
2022 EZ-GO ELITE...
SHOPBUILT S/A TRAILER (A64278)
SHOPBUILT S/A...
