SIght Glass
/ SIght Glass #1
GregH
I have a L4310 GST and the tranny sight glass is oozing fluid. Does anyone know how to tighten, replace, etc. this situation. Any help would be appreciated. You can push on the sight glass and it "gives" a little"
THanks in advance
Greg H
/ SIght Glass #2
Park the machine facing down hill or jack and support the back till you no longer see fluid in the gauge. Gently pry out with screwdriver or something suitable. Clean off the sealing surfaces, coat with black RTV/Permatex (why black? It dries quicker) and press back in, gently use a piece of wood or soft mallet if persuasion is required. Let dry and you should be on your way as long as the sight glass is'nt cracked.
/ SIght Glass
AS usual, someone steps up and comes thru in a pinch. Kubmech I appreciate the info. I was afraid it was somehow a major issue.
Thanks again
GregH
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2022 EZ-GO ELITE...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
