Mowing Side Mower
/ Side Mower #101
I am thinking that if I only want a small offset (say six inches) that I could make plates with some holes in them. Then I could unbolt the "U" support bracket assembly from the deck and use the two plates to bolt between the deck and the "U" support bracket. I think this would give me 80% of what I want. It would also help mow under over hanging branches. Easy to make and do. Easy to undo.
/ Side Mower #103
Resurrection of an old thread...
Stray? How's that mower deck holding up? I ask because I keep thinking about this mower you made and I'd like to find an old 28" snapper deck and put it under my Rubbermaid yard trailer with a canvas bag on top for a leaf bagger. I'd power it with a hydraulic motor and just let it follow me around behind the PT sucking up leaves.
/ Side Mower
Sorry moss I haven稚 been on here for a while. The mower does fine. And the size hyd motor was just right. My deck was a 28" you might go slightly larger if yours is bigger.
/ Side Mower #105
Thanks! I don't have one yet. I'm looking for an organ donor. I think the 28 or 33 would hang under the tongue of my Rubbermaid cart very nicely, although I'm not sure how high the motor will sit. I can always offset it a bit or put a box in the tongue for the motor to move up and down through if needed. Anyhow, no new projects until I get my current ones done. I have way too many in the "almost done" stages that need to be checked off the list. :rolleyes: But it never hurts to think about stuff! :D
/ Side Mower #107
Could something like this work. You just sit up on your tractor or PT and guide it with remote control.
These tend not to be stable on a slope. The caster on the front don稚 help keep it straight.
/ Side Mower #108
That mower looks sweet! I scabbed 2 together for my Kubota 6040, half alamo and half beaver. Goes out pretty far, but still seems to come 2 feet short. Can't get tractor any closer because of rocks. It gets to most of what I need then I wait until the water freezes and do it by hand.
/ Side Mower
Hi Moss. I still have and am still using that side mower. Mostly using the big red bucket for fire wood. And the right side up or upside down wood splitter. For some reason I just love to cut and split fire wood. Have the two PT's now and it is nice to have 2.
/ Side Mower #110
What is the 428 model? Was that discontinued?
/ Side Mower #111
Glad to hear all is well. :thumbsup:
TWO! Now you're just making us all jealous (well, most of us, some also have two). :laughing:
/ Side Mower
Yes I even bought a 28ef hp off of them to replace the old one in the 422. They are a Great engines but as you know in Hot weather they tend to vapor lock. Being mounted down in that tub there is just not enough air flow for them. It is a problem but i kind of wish it were more of a problem. That being it has not be a big enough problem for me to take time to solve it. Added an extra fan to one and sometime i just cool them off with a water hose. If it were a bigger problem I would do a redesign on the cover. Never a problem when ambient air is 80 deg or less. Starts very well in cold weather. Oh yes they said they would never use that motor again.
/ Side Mower
I would like to say that with my old 422 tram and wheel motors with a newly rebuilt tram pump has not nearly the pulling power as the newer 428 has. Different pump and wheel motors I guess. I'm sure the new 425's have close the same pull as my newer 428. As I guess I can now call my old 422 a 428? What would you all call it? I've also done a lot of welding and beefing up of the old one. I was hard on it.
CAT 963 GP Bucket (A68134)
CAT 963 GP Bucket...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
DIGGIT 72MM MULCHING HEAD (A65056)
DIGGIT 72MM...
2024 Kubota L47 T.L.B. 94HRS FOR SALE loaded w/options & $17K off new at $63,900!
2024 Kubota L47...
