Side link arm replacement- MF 1433
/ Side link arm replacement- MF 1433 #1
wayne48
Vermont
MF 1433v
The older I get the tireder I get cranking on the stock turnbuckle style side link arm on my MF 1433. The thing is so stiff now, I have to use a pipe wrench to turn it when I need to make adjustments.
I'm wondering what's out there in the compact tractor after market that might work with my tractor. I like the ratchet or crank handle leveling boxes I've seen on line but I haven't come across one that would work on my Massey. The stock arm is a ball socket top and fork on the bottom end.
Can anyone help me out?
Thanks
/ Side link arm replacement- MF 1433 #3
Like jerry said, a hydraulic side link. If you have rear remotes, it's pretty easy to do. If you don't then it will be a bit more effort and cost, but well worth it in the end. ;)
The side link, hose kit and flow restrictor would run you $300 + shipping.
