1930
Platinum Member
- Joined
- Sep 9, 2018
- Messages
- 934
- Location
- Brandon/Ocala Florida
- Tractor
- Kubota B6100E Kubota L 2501 Kubota T1460
I purchased a used left side cover for my B6100 ( at a high price ) only to find out that there was no clearance for the oil filter removal.
My original cover ( which is a stretched out mess ) had a factory modification that I plan to convert to this new cover but Im wondering if there was an early production B6100 that had some sort of adapter kit that had the filter originally
outside of the shroud?
I only use Kubota filters but possibly the earlier filters were much smaller? Doubtful that even with a smaller filter a person could have changed the filter without removal of the cover.
EDIT: Not that I expect anyone can help but while I have changed the cover I have also ordered and replaced all the original mounting hardware cause past owners just used whatever they could find and I want things to be correct.
Just above the filter you will see the small hole and directly behind that hole is the belt tensioner, there is supposed to be a bolt that passes thru the cover and threads into that tensioner mounting bracket.
This bolt shows up in no parts books that I have nor dealer. Its as if it does not exist. One can see the hole in the diagrams but no corresponding bolt?
Any thoughts?
Any thoughts?
