Sicma vs Ansung tiller
   / Sicma vs Ansung tiller #1
Catman8
California
Massey Ferguson 30B, John Deere 2032R
I can't make up my mind between the Sicma T5-60 made in Italy or the Ansung yjco62 made in Korea tillers. I have a JD2032R, tractor hp 31.7, PTO hp 23.5, tire width is 55". I will be tilling three acres of soft decomposed granite, after it rains you can dig it with a spoon and it's not very hard when it's dry, and not many rocks. I want to buy a quality tiller not a cheap o. Is the extra weight going to be an advantage or disadvantage with my size tractor, are the adjustable blocks a plus when you have a narrow distance between your rear wheels. Does the extra weight of the Ansung mean it's a better tiller or does the Sicma make up for the loss in weight with quality steel, more tines, or better parts. Appriciate your input .
The Sicma weighs 441 Lb, PTO hp required 20-35' and has 42 blades, Adjustable/Off Setable Lower and Upper Hitch Blocks (for up to 4" of offset), three year warranty on gear box, $2,324.00
The ETA Ansung weighs 533 lb, PTO HP required 25-40, and has 36 blades, five year warranty on gear box. $2,071.00
   / Sicma vs Ansung tiller #2
Yes, weight is your friend providing you have the hp and the hydraulics to lift it. I personally liked the Sicma all around for quality of build and more tines.
I like the fact that the Sicma has been around for many years and that they are made in Italy, and that this model has more tines, maybe more tines makes up for the 92lb difference. On the other hand the Ansung is heavier, five year warranty, and a gearbox that is like a cars rear end differential that is supposed to be quieter. Hummmm, that's the problem with not being able to see a side by side comparison to see the build quality. Thanks for your opinion Oldtink.
   / Sicma vs Ansung tiller #4
If your ground is hard, FEWER tines will cut better than more tines, however the bed behind the tiller will be a bit coarser.
(( More horsepower per tine. ))
why is Sicma saying you only need 20 hp, vs 25 is it because they have more tines. The more tines you have the less hp you need, or just the opposite.
   / Sicma vs Ansung tiller #6
The more tines you have the more HP is required to drive it
The Ansung has less tines then the Sicma and Ansung is saying you need more hp to run their tiller, why is that.
   / Sicma vs Ansung tiller #8
How are the tines driven? Center mounted car rear end types leave a untilled area in the middle that the side mount chains or gears drives do not. Side mount gears/chains till more uniformly. There is 90 lbs more of something in the Ansung! That's 23% more for less $.
   / Sicma vs Ansung tiller #9
More tines means you will need more hp, but it will do a better job too...
I'm NOT fond of tillers with less tines on the flanges and wouldn't buy one!
Personally, i'd be looking at one of the better models of Maschio or Kuhn tillers... But, with only 23hp you wouldn't be able to power a HD tiller as wide as you are looking at.
Well built HD tillers cost a lot of $ too, probably more than you are willing to pay...
SR
   / Sicma vs Ansung tiller #10
All I can say is I have the Ansung YJR074 and I am running it with 26.5 HP - supposed to take 50. However as I have a hydro tractor I can slow down and let it work. It is built like a tank - No problems. You want a tiller wide enough to cover you tractor tracks. Many times the HP rating is to get a heavier tractor to lift and operate. In tillers weight is your friend so they do not bounce as much. As for less tines not giving a smooth bed, I call foul - you just need to go a bit slower on the final pass and it will be fluffy and smooth.
The YJC is chain driven - I would recommend moving up to the gear driven YJR062 which is heavier and has more tines. YJR Series It is a more durable unit.
Both of these models are chain driven on the end, does 90 extra pounds equal a quality built machine or just extra steel? And I'm not implying that the Ansung is not quality, I don't know, if I took and welded a 90 pound piece of steel to the Sicma for extra weight would it make the difference.
Can my tractor handle a YJR062, I don't want to get something that my tractor can't handle. I don't mind spending a lot of money as long as I get a well built tiller that will last. Do you feel that you are over stressing your tractor running the HD tiller.
SR
Who sells Maschio and Kuhn, you have a link to an online distributor.
   / Sicma vs Ansung tiller #15
I HAVE A SICMA 6 FT TILLER I PROABLY USE IT ABOUT 100 HOURS A YEAR IT HAS BEEN THE BEST I HAVE EVER USED CLIENTS COMMENT ON HOW GOOD GOOD A JOB IT DOES
   / Sicma vs Ansung tiller #16
Beats me?? They are sold numerous places around here...
I'm from a generation that likes to look tools over and see for myself how they are built, going on line and reading brochures or asking owners about how a certain tiller held up in an acre or two a year, or for a few garden spots each year does not make a HD long lasting tiller.
I've been doing commercial tilling since the 80's, so I buy equipment that's made to last, so asking some one who tills a few gardens a year, just won't tell me how good a tiller is.
This Howard tiller is coming up on 2000 acres that "I" have tilled with it, and I bought it used!!
It's chain drive and sprockets are all original and still in GREAT shape, I prefer chain drive to gear drive as it takes shock loads better.
I have two other Howards with chain drive that are all original too...
SR
   / Sicma vs Ansung tiller #17
I think you can handle it, but it will be maxed out. You have hydro-static drive so you should be OK. Being from California there should be dealers that have these in stock you can check out. Haul you tractor there and try. Also look around with agg rental folks or some big rental places and see what they have. I got mine used out of my local Agg rental place. Woods and Howard are also good choices. Good luck in you choice
Thanks everyone for your advice, I also like to see equipment in person, unfortunately not many places around here stock attachments for you to look at and compare. I have never owned a tiller, do you drag the tiller on the ground or is the tractors three point holding most of the weight at a set height?
   / Sicma vs Ansung tiller #19
I have an old 48" maletti p-120S that was built in '78 and is In excellent shape other than needing tines now... I bought it used and till probably close to 20 acres yearly with it. Since i owned it the only issue I had was the O.E PTO shaft splitting and one O.E u-joint go bad. I keep it greased, good oil in the boxes and grind away with it. I'm sure the brand new price of the maletti was less than a howard or "main brand names" back then.
Rumor I hear is kuhn bought out maletti tillers. Also heard that maletti built tillers for Kubota and other implement companies.
I just updated to a 60" King Kutter tiller but have been plagued with rain preventing me from really giving it a good run yet. Lots of kk tillers out there with very good reviews and comments. Uncle has one and it does not live an easy life in his rocky dirt and has never a problem over the years of tilling he has done.
I did hear the 647, 665, 672 if my model numbers are correct, line of deere 3pt tillers are just green sicma 3pt tillers. I did look both over and would believe that speculation to be true.
   / Sicma vs Ansung tiller #20
Three point does not lift during operation (except to turn around, then you kill the PTO, lift and reset). You set the side skids for the tilling depth per instructions, drop the tiller on the ground and go. It will seek its on depth depending on the ground condition and speed. trick is not to go too deep all at once as that puts a lot of load on the tractor. Now having said all the above, I have used my 3 pt to adjust the height as I go depending on conditions. It easy to get the hang of if you go slow and pay attention. Just dont sit and bang on a rock :eek: I strongly suggest trying to rent one to get a feel for what you can handle. There hast to be someplace around you that rents. Call around to the Agg dealers and rental shops, even if you need to drive and hour - it would be well worth it.
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Pat's QH and hydraulic top-link.
Pat's QH and...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A59230)
2004 Pierce Tilt...
