sicklebar mower
/ sicklebar mower #21
RichZ,
My dad has used the type of equipment that cowboydoc describes, for over 20 years. (sickle bar mower, pull behind crimper, very old rake, baler that originally had its own engine, and wagon) He has a gentlemen farm that required haying about 12 to 25 acres, two cuttings per year. As one that helped with much of the labor to get this hay in, I agree with others here, that it will be challenge with double the amount of acres. If memory serves me, we would do about 12 acres at a shot. This would take approx three days to cut, crimp, - day1, rake, rake, - day2, rake, bale, and store - day3. This is all dependant on getting three good drying days. Not always possible in Central NY. Baling would usually start about noon on the 3rd day, and would be still storing it in the mow, well past dark. We would start picking-up the bales as soon as the baler had made two passes around the field, i.e. seperate tractor/wagon. A crew of three, worked the pick-up and storage, while dad continued to bale. Not sure, but think this was around 300-400 bales.
I don't remember having much problems with the mower or rake. The crimper tended to jam with hay, at least once or twice during the 12 acres. Required cutting pulling the hay out of the rollers. The baler held up well, except for the knot tyer. This would fail at least once an outing, depositing a few broken bales, which had to be re spread and rebaled.
All in all, this equipment is still around and functioning today. Only does a total of 12 acres, 6 at a shot. Only has 1 horse now. My cousin will gladly take any access.
In short, it will be possible to do 50 acres, but don't under estimate just how much work it will be.
PS: I do still remember the smell of freshly stored hay. Also, remember fending off the wasps that always inhabited our mow!
JohnS
/ sicklebar mower #22
Hi ya's
.02 cents here moco's are good but over rated in my mind if doing more grass based /thin stemed alfalfa hay a flat bar mower will do the job there is a mower in nz that spreds as it mows and time after time wilt/dring time is faster also keep in mind a moco will let water out but will let water back in faster .some of the old alfalfa's where like pea vines(wl320 comes to mind) and the leaf would dry out in 2 days but the stem took a week (nz times)new types have better /finer stems .disc mowers are faster but take a bit more Hp to drive ,sicklebar mowers look for the pitman less type ie gearbox on cutter bar also serated knifes or twin knife most of all keep sharp with the way ya talking bout doing 50 acres i'd be doing it in stages 10-15 acres at a time if something goes wrong it's less to lose,, nothing can match ya baler braking down ,rain comeing and 45 acres left to bale.other prob with moco's is some make rows to big for smaller gear to handle no point makeing rows from a 10 foot mower if ya baler can't take it better haveing the whole field spred out and building rows to suit ya gear
catch ya
JD Kid
/ sicklebar mower #23
Jd,
A mower conditioner will dry hay, grass or alfalfa, faster than not conditioning it anyway for any hay I've ever done. With a conditioner you can mow one day and be raking the next. Without conditioning you are waiting a few days before you can rake. Even say it did let more moisture back in, not sure about that, but it would still dry out faster when the moisture was gone than not being crimped. Also you can vary your rows with the mower conditioner to fit whatever your baler is capable of doing. You can also only rake one row instead of two rows together to bale. Even that old baler that I had last year would bale two rows from the moco and it was a 1960's model. I don't know of anyone that does any serious haying that doesn't have one. Yes you can do it without but it's much faster and easier with a moco, in my humble opinion.
Growing up all we ever had were swathers. It's like moco attached to a combine. That sure made haying easy and nice. Then we had hay stackers to pick them up. Still not sure why that kind of equipment isn't used in the midwest but you never see any of the hay stackers or swathers.
You are certainly right about just doing one piece at a time though. Problem there though is that, as you know, when hay is ready it's ready. To get the full nutrient value if you cut too soon or too late you lose. Tough call in that area. That's my main concern for them baling with old equipment with that much ground.
/ sicklebar mower #24
Hi ya Cowboydoc
a few points i have had 3 diffrent moco's 2 rollers and 1 rub type each has there good and bad points rollers good for alfalfa and clovers but not worth it if just doing grass the other is to hard on leaf on alfalfa/clover.if the stem is cracked it will let in water a lot faster i know guys here in wetter areas who will not use a moco but will use a tedder to spred .yes it will dry faster and more even if set right amount of crimping and row size comes in to play too.i have gone to a flat bar mower in the past few years cost come in to it 12000 for a 10 foot mower Vs 45000 for 10 foot moco running costs were also lower ,baleing 8000-15000 bales a year (small bales)even with doing that amount the numbers did not stack up...ok other point cut early or late early cutting will shorten the life time of alfalfa but better feed value cutting latter the feed value drops so timeing like ya say is a big thing ,we used to find frist cut was hard to get as good hay so we made most of frist cut into balage and try and get main cuts of hay in better drying condishions(?)or even graze longer to get later flowering . good gear comes in to it brakedowns cost time and money ..ya baler has to be the strongest link ie if ya mower brakes ya field dose not get cut if ya baler brakes ya hay could get wet!!!! with out knowing how bigger a window ya have each day to bale it's a hard call ,for me a baler has to do around 600+small squares per hour (or =in round/big bales)on our new place that may mean this year i only bale for 2 hours but once i get more hay fields in (good markets around us as 99% buy in each year)that will get bigger
catch ya
JD Kid
/ sicklebar mower
Boy, I'm offline for a couple of days, and I started quite a thread!!
Richard, I know everything you say is 100% correct, but I just don't have the funds to do it the right way...Yet!!! John Miller knows my situation well, and what he describes is accurate. I will attempt to get hay growing well on 50 acres. If my equipment can't handle the job, I'll do what I can, and get as much baled as I can. I realize there's no way I'm going to be able to get all 50 acres harvested several times, next year. I'll be lucky to get a few dozen at each time, and then I'll brush hog the rest just to keep it in good shape. As John said, in time I'll have the proper equipment, but I'll have to start with junk equipment, and work my way up. John know that I am very tenacious. I'm new to all this, and feel I've accomplished alot in my first year, due to the invaluable advice of all my friends on TBN. And with the great fortune I've had to live near John, and go to auctions together, I've learned even more. He's taught me what to look for, and when to buy new, and when to "make do".
Richard teaches me what to strive for, and points me in the right direction. It may take a few years, but with friends like John and Richard, and the rest of you guys,I'll have a nice hay crop eventually. For the time being, I'm hoping to be able to harvest enough for our animals next year. Eventually my friend and I hope to even be selling some hay, but we know that's way down the road!!!
If I manage to sell alot of antiques this winter, I'll be buying alot of equipment this spring, and John and I will have a blast at the auctions!!! (we have fun at them even when we don't buy anything!!!)
Thanks, guys!!!
It's great to be a part of TBN!!!/w3tcompact/icons/smile.gif
Rich
/ sicklebar mower #26
Rich,
I know how you feel and good luck with it. Are you going to be doing grass or alfalfa hay? If you're doing alfalfa and you don't cut it it will go to seed and die out really fast. I would stick with grass hay if you're not going to be able to cut it all. Also alfalfa does not do very well if it gets covered for any amount of time as well. So if it gets tall and you mow it down and don't bale it it will probably kill the alfalfa where you mow the other on top of it. What is the ground right now?
/ sicklebar mower
Thanks, Richard! We'll be doing grass. All the land is either former pasture or hayfields, so the basis is there. I just finished brush hogging all of it, to cut the weeds and brush. Some of it is in real nice shape, because my friend has had someone round bale it. The thing is, here in NY everything is more expensive. My friend was charged $20 per bale just to bale it!!!/w3tcompact/icons/shocked.gif I told him that I could buy round bales for less than that. Then I found out he used to square bale it, and still had some equipment, though most of it is in need of repair. He stopped because he couldn't handle it alone, his wife and kids weren't helping, and my wife and I are eager to get started!. That's when I suggested we go into a partnership. So, I'm trying to aquire equipment and have what of his is salvagable, repaired.
Sometimes I luck out! Last week, I got an old pto driven, John Deere manure spreader, from our county fairgrounds. It was only used one week per year, and was kept in a barn. Before the county sold it to me, they replaced the chains, greased the bearings, painted it, and generally tuned it up. It's in the best shape of any used manure spreader I've ever seen, and I only paid $600 for it. I've seen total wrecks go for more than that at the auctions John and I go to!
So with a little more luck, and a lot more guidance from you guys, I'll get there!! There are bargins out there if you look hard enough! At the last auction John and I went to a nice massey Ferguson 175 went for only $2400./w3tcompact/icons/shocked.gif It might have been a million dollars, because at the time I couldn't afford it./w3tcompact/icons/mad.gif But if all goes well with the antique sales, I won't let a deal like that get away this spring If I do, John will kill me!!)./w3tcompact/icons/laugh.gif
Rich
/ sicklebar mower #28
That makes things a whole lot easier then Rich. With grass it's not that big of a deal like it is with alfalfa. If the grass turns you will lose some of the nutrient value but nothing like alfalfa. I was thinking you were going to replant all these fields and such. Yea grass isn't near the big deal that alfalfa is. You can even get grass wet and it can dry and you can bale it without near the loss you get with alfalfa. It will do you good to start on grass it's alot more forgiving than alfalfa. Doing grass and doing it in sections you should be able to get by with older equipment.
/ sicklebar mower
Thanks, Richard, that makes me feel alot better. I'll keep you posted of my progress, and I'm sure I'll have alot of questions!
I finished brush hoging last weekend. This weekend, I'll be spreading manure!!! I never thought I'd be this excited by spreading horsesh**!! Maybe I should've been a politician!!/w3tcompact/icons/laugh.gif
Rich
/ sicklebar mower #30
The place I bought my tractor has a large selection of used equipment. Perhaps this will give you an idea of prices for used equipment.
Case IH 8312 Disc MoCo, Cutterbar & Rolls - $4,900
NH 315 Baler w/70 Thrower - $3,700
They have a web site that has all their used equipment listed with pictures of most of it. They may not be close to where you live, but it might be good for developing a wish list, Messicks
/ sicklebar mower #31
RichZ
There maybe one safety issue regarding a sickle mower you may not be familiar with. Watch were you place your hands when you lift the bar to secure it for traveling. DO NOT place your fingers between the teeth and guards, the section WILL shift/slide and you'll be without some of your digits.
By the way, my cousin and his neighbors annually put up 12,000 (yes 12,000) square bales with a Farmall 'A' and PTO baler, also using a sickle mower, and rake. I'm not saying it's the most efficient means to do that must baling, just that it CAN be done. Stay safe.
Terry
/ sicklebar mower #32
Are there any rules of thumb about sizing a sicklebar mower to a given size tractor. I would like to find a used workable mower to cut ditch banks. What I don’t know is how big of mower my B21 with loaded tires could pull.
MarkV
/ sicklebar mower #33
Doesn't take much power to run a sickle mower. Minimum probably 15-20 hp for a 7-9' bar. A B21 should be ok. I would strongly recommend a 3pt type for roadsides. Then the mower doesn't have to travel down the rough edge of the road and the bar is easily lifted to hang over the edge of the road.
/ sicklebar mower #34
Mark,
Radman is right you should be fine for an older sicklebar mower. They don't take much hp.
/ sicklebar mower #35
Hi ya
yep ya right bout the folding of the bar about 16-18 years ago i gave a mate a hand mowing a field when finshed we packed up the pitman was not in the right place so i could not fold he put a spanner under it and jumped on it well they are fast cutting and the only thing i felt was a bit of numbness and blood running down my arm ,the scar is still there 9 stiches but they could not get the nerves to mend ,good point ya make...like the old saying "keep ya fingers out of the fingers!!"
catch ya
JD Kid
/ sicklebar mower #36
Sorry to hear that JD Kid. My uncle was crushed to death under his farm truck, so I try to keep my head screwed on straight around my tractor - sometimes I even manage too. Take care, and stay safe.
raptor
/ sicklebar mower #37
<font color=red>and the other item is cost... dirt cheap that is workable</font color=red>
Sounds like my budget./w3tcompact/icons/smile.gif I tend to be a bottom feeder, You got a POS that needs a ton of work, and you want to get rid of it? I’m you guy. Luckily I love fixing things. I don’t know what I would do with something new, I would be board. So if anyone has an old tractor out there that needs a LOT of work…………../w3tcompact/icons/smile.gif
/ sicklebar mower
Paul, you're right. You can sometimes get great deals on used stuff, and if you're lucky, it may not even need work. I can't afford most new stuff. So far I've gotten my tractor, and half my implements used. I haven't had to put any work into any of them (Although, eventually my tractor did need a minor repair to the 3 point hitch), and I've been extremely satisfied with them all.
I just used my new (to me) manure spreader this weekend. It's an old John Deere, form the 60's but in great shape. In fact when I was using it, 2 neighbors saw me from the road, and came over to check it out. They said most new manure spreaders don't work as good! And they were both lifelong farmers, so I'm pretty satisfied!
Rich
/ sicklebar mower #39
Sometimes I think I like working on them more then using them. But I am a little strange./w3tcompact/icons/crazy.gif
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
2011 Ford E-250 Cargo Van (A66736)
2011 Ford E-250...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
KOMATSU D31PX Blade / C-Frame (A68134)
KOMATSU D31PX...
2009 Chevrolet 3500HD (A64911)
2009 Chevrolet...
