Sickle Bar Sickle mowers
   / Sickle mowers #31
flusher... you got a great deal.
"AC 80T sicklebar--the trailer version of your 3pt 80. Bought it from a neighbor for $150."
These are among the best sickle mowers built.
Tractor supply carried the rock guards with ledgers, very reasonable. I have only replaced one sickle section, the one that met the t-post. KennyV
   / Sickle mowers #32
My husband just found a ford 505 and can buy it for 350.00 it works good and was showed by seller that it worked but your post is the only thing i can find any info on this sickle mower. Is it worth that and can you tell me any info on them good or bad? Thanks
   / Sickle mowers #33
My 80T works fairly well now, but I really need to install new sections and a few new guards.
   / Sickle mowers #34
Funny thing... I just broke a guard today...
Tractor Supply has always had them for less than $5... Hope they still have them in stock. I have used up my extra that I had...
The sections are a pain BUT when you replace them get the Bolt on kit, available on Ebay .. It is a LOT easier to do than rivets...
I have sharpened my set several times, getting close to needing replacement also... KennyV
   / Sickle mowers #35
I have a 501 ford sickle bar mower. I get my blades, ptman arm, guards, bolts at TSC, other stuff I get at WALT's tractor on the net (Walts Tractor Parts, Manuals and replacement parts for Farm Tractors). I have been using it since 2007. I have cut about 10 to 20 acres a year and $350 is not bad. Keep it greased well that will reduce the number of pitman arms you replace.
2011 JACK COUNTY 130 BBL VACUUM  TRAILER (A58214)
2011 JACK COUNTY...
2020 CAT 308 (A53317)
7021 (A55851)
7021 (A55851)
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
