Sickle mower let me down big time
/ Sickle mower let me down big time #1
powerscol
SW Colorado
CT 235
Went to cut very heavy grass Saturday (crested wheat brome, etc.) Set up the IH 1300 just as I did this spring, dressed up the near new knives (only cut 20 ac so far) and it kept floating out of the hay and plugging. I tried pitching the bar down and up, but it just would not cut well. Also varied speed - faster seem better at first, then kept tripping. I am using under-serrated knives as recommended.
I guess I need to break down and get a drum mower and tedder.
Pretty bummed out today over this and the rain, but work did not allow me to cut earlier which I should have.:(
/ Sickle mower let me down big time #2
Not positive I understand, but if you kept the cutter too high it's not going to cut worth a darn. It needs to be within a few inches of the ground to cut properly.
Edit: Never mind, I misread your explanation. But you will never regret upgrading your cutter. I would hire someone to cut my hay before ever using a sickle bar mower again.
/ Sickle mower let me down big time #3
Buy something with a reel that can empty the knife area. What's the guard clearance, or is this a cut-hay flow problem ?
Guard clearance looks good, as well as knife hold down tension. Primarily it was a flow problem, mainly at the outer 1/3 . Perhaps I need more weight at the bar end. Currently set to the recommended weight of 25 lbs to lift outer shoe, and 75 lbs at the inner shoe. I do have the shoes set for max height to prevent scalping.
Appreciate any thoughts.
/ Sickle mower let me down big time #6
That sums it up. We still have a sicklebar mower that was bought new many years ago. Even when new it was a plugging POS. Disc mower arrived mowing rate went up significantly.
/ Sickle mower let me down big time #7
Yep. My sickle is for cutting ditches and steep roadside banks now.
Cheap JD 1209 mowco does a way better job and is way faster, especially in thick hay like you are describing.
Yes it was thick grass and damp underneath, even though I let the field dry a week. We have been getting heavy dew in the mornings though.
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A59228)
2025 GIYI GY-PG72C...
2018 KAUFMAN 44 FT CAR CARRIER TRAILER (A59905)
2018 KAUFMAN 44 FT...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
