SHUTTLE SHIFT, REDUCE POWER first?
   / SHUTTLE SHIFT, REDUCE POWER first? #1
geekwithoutacause
MF1240
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?
Sorry if this is a dumb question.
   / SHUTTLE SHIFT, REDUCE POWER first? #2
I reduce speed, not power on our M8540, no question is dumb, these things are expensive.
   / SHUTTLE SHIFT, REDUCE POWER first? #3
:welcome:
To TBN GeekWOAC. You have come to the right place to get answers.
Yes, I do stop the tractor when going from forward to reverse and back to forward... But you don't lower the rpm's before you operate the shuttle valve? The original manual states that.?
   / SHUTTLE SHIFT, REDUCE POWER first? #5
I just reduce speed to almost a stop before changing directions . I very seldom run at a high rpm , if I was I would reduce rpm some along with speed .
   / SHUTTLE SHIFT, REDUCE POWER first? #6
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?.
I do.
I throttle down before forward/reversing. That's what the foot throttle is for.
(my tractor is not a power reverser. Shuttle with a dry clutch)
   / SHUTTLE SHIFT, REDUCE POWER first? #7
I do 90% of my work at idle or just above. If I'm operating at PTO speed I use the foot clutch in conjunction with the hand shuttle.
Welcome to TBN.
So when I am moving dirtpiles, is it easier to use the footpedal ?
Thanks for the comments.
   / SHUTTLE SHIFT, REDUCE POWER first? #9
Not if I am running a bush hog, I have areas on levies and hills where frequent changes in directions, so I leave it at 540 RPM. I also did our Case CX80 with synchro shuttle.
When our M8540 was delivered I specifically asked this as the M8540 has a hydraulic clutch. Moving dirt, grapple, I use the foot pedal o vary RPM.
   / SHUTTLE SHIFT, REDUCE POWER first? #10
ABSOLUTELY! That's my main use for my 4310, a loader tractor. It has the powerReverser 12X12 trans. I only touch the clutch once when i start it; everything else is done with the foot throttle and shuttle. I usually give it 1 second in neutral when switching directions. Hope this helps!
CLUB CAR 10 ELECTRIC GOLF CART (A51244)
CLUB CAR 10...
2021 KOMATSU D51EX-24 CRAWLER DOZER (A51242)
2021 KOMATSU...
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
2006 Ford F-150 Pickup Truck (A50323)
2006 Ford F-150...
2009 Chrysler Sebring (A50324)
2009 Chrysler...
