SHUTTLE SHIFT, REDUCE POWER first?
/ SHUTTLE SHIFT, REDUCE POWER first? #1
geekwithoutacause
MF1240
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?
Sorry if this is a dumb question.
/ SHUTTLE SHIFT, REDUCE POWER first? #2
I reduce speed, not power on our M8540, no question is dumb, these things are expensive.
/ SHUTTLE SHIFT, REDUCE POWER first? #3
:welcome:
To TBN GeekWOAC. You have come to the right place to get answers.
Yes, I do stop the tractor when going from forward to reverse and back to forward... But you don't lower the rpm's before you operate the shuttle valve? The original manual states that.?
/ SHUTTLE SHIFT, REDUCE POWER first? #5
I just reduce speed to almost a stop before changing directions . I very seldom run at a high rpm , if I was I would reduce rpm some along with speed .
/ SHUTTLE SHIFT, REDUCE POWER first? #6
Hi all,
New to tractors. Got a MF1240 in pretty good shape. Reading the operator manual it states to reduce power before shifting from Forward to Reverse. Is that needed?.
I do.
I throttle down before forward/reversing. That's what the foot throttle is for.
(my tractor is not a power reverser. Shuttle with a dry clutch)
/ SHUTTLE SHIFT, REDUCE POWER first? #7
I do 90% of my work at idle or just above. If I'm operating at PTO speed I use the foot clutch in conjunction with the hand shuttle.
Welcome to TBN.
So when I am moving dirtpiles, is it easier to use the footpedal ?
Thanks for the comments.
/ SHUTTLE SHIFT, REDUCE POWER first? #9
Not if I am running a bush hog, I have areas on levies and hills where frequent changes in directions, so I leave it at 540 RPM. I also did our Case CX80 with synchro shuttle.
When our M8540 was delivered I specifically asked this as the M8540 has a hydraulic clutch. Moving dirt, grapple, I use the foot pedal o vary RPM.
/ SHUTTLE SHIFT, REDUCE POWER first? #10
ABSOLUTELY! That's my main use for my 4310, a loader tractor. It has the powerReverser 12X12 trans. I only touch the clutch once when i start it; everything else is done with the foot throttle and shuttle. I usually give it 1 second in neutral when switching directions. Hope this helps!
Oh so you use footpedal but no clutch when using the shuttle valve? I guess I was doing the opposite..:laughing:
edit: just looked it up in the mf1240 operator manual. It states to reduce engine rpm AND press the clutch.
/ SHUTTLE SHIFT, REDUCE POWER first? #12
Easy now, his description of useage is deceiving.
/ SHUTTLE SHIFT, REDUCE POWER first? #13
Well, I suppose you should follow the manual. Do you have a fully synchronized trans? Do you have to bring the tractor to a stop to shift?
edit: I just looked up your mf1240 & my jd4310....dry disc vs wet. that's why you need to clutch to shift the shuttle. I would drive it like the old dump truck... alternating feet you're either on the clutch or the foot throttle. make sense?
/ SHUTTLE SHIFT, REDUCE POWER first? #14
I tend to hesitate just a moment before utilizing the shuttle. I hardly ever run at higher RPM's unless I am bush hogging. I run at the rated RPM. Typically I run around 1500 to 1800 RPM's. With the hydraulic shuttle I do not depress the clutch.
/ SHUTTLE SHIFT, REDUCE POWER first? #15
Much easier for the operator and clutch IMO.
I always use my foot throttle to throttle up/down for forward/reversing for loader work, mowing, brush mowing, ETc. Etc.
