shuttering 3 point hitch on L3450 Need help
   / shuttering 3 point hitch on L3450 Need help #1
david.phillips181
Hi there new to the site and looking for ideas on ajusting or fixing my 3 point. My 3 point goes up and down when unloaded just fine. The 3 point will hold weight in the up position all night without sinking. If you pull the depth control level quickly and stop the 3 point lifts without issue. If you go slowly with the attachment on it jerks the tractor all over the place. 650 hours service has been completed. I quickly played with the one adjustment on the 3 point without luck
Any ideas??
I've only had the tractor a couple of weeks and didn't have any attachments until now. I also just removed the front mount blower (controlled by the loader valve)
   / shuttering 3 point hitch on L3450 Need help #2
Any ideas??
Leak on the suction side of the hydraulic pump. Spin on filter?? Is it tight?
larry
   / shuttering 3 point hitch on L3450 Need help #3
Sounds more "mechanical" to me...Make sure all the pivot points for the rockshaft lever and the feedback linkage are lubricated.
2008 FORD F-750 (A50854)
2008 FORD F-750...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Display Shelf and 2 Drawer File Cabinet (A49462)
Display Shelf and...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
