shuttering 3 point hitch on L3450 Need help
   / shuttering 3 point hitch on L3450 Need help #1
david.phillips181
Hi there new to the site and looking for ideas on ajusting or fixing my 3 point. My 3 point goes up and down when unloaded just fine. The 3 point will hold weight in the up position all night without sinking. If you pull the depth control level quickly and stop the 3 point lifts without issue. If you go slowly with the attachment on it jerks the tractor all over the place. 650 hours service has been completed. I quickly played with the one adjustment on the 3 point without luck
Any ideas??
I've only had the tractor a couple of weeks and didn't have any attachments until now. I also just removed the front mount blower (controlled by the loader valve)
   / shuttering 3 point hitch on L3450 Need help #2
Any ideas??
Leak on the suction side of the hydraulic pump. Spin on filter?? Is it tight?
larry
   / shuttering 3 point hitch on L3450 Need help #3
Sounds more "mechanical" to me...Make sure all the pivot points for the rockshaft lever and the feedback linkage are lubricated.
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
71069 (A49346)
71069 (A49346)
2014 Nissan Frontier Pickup Truck (A50323)
2014 Nissan...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
