shuttering 3 point hitch on L3450 Need help
   / shuttering 3 point hitch on L3450 Need help #1
david.phillips181
Hi there new to the site and looking for ideas on ajusting or fixing my 3 point. My 3 point goes up and down when unloaded just fine. The 3 point will hold weight in the up position all night without sinking. If you pull the depth control level quickly and stop the 3 point lifts without issue. If you go slowly with the attachment on it jerks the tractor all over the place. 650 hours service has been completed. I quickly played with the one adjustment on the 3 point without luck
Any ideas??
I've only had the tractor a couple of weeks and didn't have any attachments until now. I also just removed the front mount blower (controlled by the loader valve)
   / shuttering 3 point hitch on L3450 Need help #2
Any ideas??
Leak on the suction side of the hydraulic pump. Spin on filter?? Is it tight?
larry
   / shuttering 3 point hitch on L3450 Need help #3
Sounds more "mechanical" to me...Make sure all the pivot points for the rockshaft lever and the feedback linkage are lubricated.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
