shredder size for given HP?
/ shredder size for given HP? #1
bdog
Elite Member
Texas
John Deere 6130M
I am looking at buying a tractor to do some commercial shreeding. Basically running an ad in the paper and mowing vacant lots, etc. I was thinking anywhere from 5-7 foot but am unsure what size tractor I need for these. I definitely don't want to be underpowered and have problems as I need to mow quick in order to make money but at the same time I don't want to spend any more money upfront on a tractor than I need too.
/ shredder size for given HP? #2
RULE OF THUMB: For heavy work, 5 PTO HP per every 12" of width of the cutter. So a 5' cutter would require 25pto HP.
/ shredder size for given HP? #3
In addition to what Bob said, make sure the tractor can lift the cutter you buy. A heavy-duty cutter weighs a LOT more than a light duty one does.
It is possible you could have enough PTO HP to run a heavy duty cutter, but not have enough tractor to handle one... /forums/images/graemlins/crazy.gif
/ shredder size for given HP? #4
<font color="green"> It is possible you could have enough PTO HP to run a heavy duty cutter, but not have enough tractor to handle one...
</font>
Henro, good point. When I have the FEL off, I slip 100# wheel weights on the FRONT wheels to hold the front end down.
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
John Deere 24in Backhoe Bucket (A65640)
John Deere 24in...
Case 1044 Combine Head (A65640)
Case 1044 Combine...
Westfield Gravity Wagon Auger (A66408)
Westfield Gravity...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
