Show us your Best Stuck
   / Show us your Best Stuck #23
Where were you going? Looks like the end of the road.
Spraying some houndstongue. I was at the end of the area I was spraying an was attempting to turn around when the tires dropped into some soft ground.
   / Show us your Best Stuck #25
I have posted this one before. This was about a year ago. I went through that area several times before finally sinking.
   / Show us your Best Stuck #26
:DThis is my Bad Stuck!! After I got stuck I went to get help & brought a Cat D-4 & operator in to help. He managed to get stuck with me, then he called his boss & brought the cat trackhoe to get us both out in about 10 mins. By the way we were on the side of a hill & it was dry on both sides of us!! Must've been a spring head.:D
   / Show us your Best Stuck #27
What do you pull with the trailer hitch on the back of your mulcher?
   / Show us your Best Stuck #28
That is what I chain to, when transporting on the trailer or getting pulled out of a bog. In the woods it acts as a bump stop when I center something! I haven't pulled anything with it.
   / Show us your Best Stuck #29
This is as stuck as I ever had the old mahindra 6025, slipped into a trenched hole and had to dig her out with a track hoe. Traded up to a 4wd 8560 shortly thereafter. Wouldn't have another 2wd tractor. Not for the situations I get myself into.:)
You will have so much more fun with 4/WD, Then you can bury all 4 wheels instead of just 2. Don't ask how I know that or how many times it has "Happened".
When you get your 4/WD, get a back hoe and FEL, most of the time 1 or the other will pull or push you out. Might add a winch if your area has something to tie off too.
NOTHING IS MORE DANGEROUS THAN SINCERE IGNORANCE
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2016 FREIGHTLINER CASCADIA DAYCAB (A55745)
2016 FREIGHTLINER...
Kubota RTV500 (A47384)
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
