Show us your Best Stuck
   / Show us your Best Stuck #23
Where were you going? Looks like the end of the road.
Spraying some houndstongue. I was at the end of the area I was spraying an was attempting to turn around when the tires dropped into some soft ground.
   / Show us your Best Stuck #25
I have posted this one before. This was about a year ago. I went through that area several times before finally sinking.
   / Show us your Best Stuck #26
:DThis is my Bad Stuck!! After I got stuck I went to get help & brought a Cat D-4 & operator in to help. He managed to get stuck with me, then he called his boss & brought the cat trackhoe to get us both out in about 10 mins. By the way we were on the side of a hill & it was dry on both sides of us!! Must've been a spring head.:D
   / Show us your Best Stuck #27
What do you pull with the trailer hitch on the back of your mulcher?
   / Show us your Best Stuck #28
That is what I chain to, when transporting on the trailer or getting pulled out of a bog. In the woods it acts as a bump stop when I center something! I haven't pulled anything with it.
   / Show us your Best Stuck #29
This is as stuck as I ever had the old mahindra 6025, slipped into a trenched hole and had to dig her out with a track hoe. Traded up to a 4wd 8560 shortly thereafter. Wouldn't have another 2wd tractor. Not for the situations I get myself into.:)
You will have so much more fun with 4/WD, Then you can bury all 4 wheels instead of just 2. Don't ask how I know that or how many times it has "Happened".
When you get your 4/WD, get a back hoe and FEL, most of the time 1 or the other will pull or push you out. Might add a winch if your area has something to tie off too.
NOTHING IS MORE DANGEROUS THAN SINCERE IGNORANCE
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
CAT 320B Excavator (A54865)
CAT 320B Excavator...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
3 - JACK STANDS (A55745)
3 - JACK STANDS...
