Show us your Best Stuck
/ Show us your Best Stuck #23
Where were you going? Looks like the end of the road.
Spraying some houndstongue. I was at the end of the area I was spraying an was attempting to turn around when the tires dropped into some soft ground.
/ Show us your Best Stuck #25
I have posted this one before. This was about a year ago. I went through that area several times before finally sinking.
/ Show us your Best Stuck #26
:DThis is my Bad Stuck!! After I got stuck I went to get help & brought a Cat D-4 & operator in to help. He managed to get stuck with me, then he called his boss & brought the cat trackhoe to get us both out in about 10 mins. By the way we were on the side of a hill & it was dry on both sides of us!! Must've been a spring head.:D
/ Show us your Best Stuck #27
What do you pull with the trailer hitch on the back of your mulcher?
/ Show us your Best Stuck #28
That is what I chain to, when transporting on the trailer or getting pulled out of a bog. In the woods it acts as a bump stop when I center something! I haven't pulled anything with it.
/ Show us your Best Stuck #29
This is as stuck as I ever had the old mahindra 6025, slipped into a trenched hole and had to dig her out with a track hoe. Traded up to a 4wd 8560 shortly thereafter. Wouldn't have another 2wd tractor. Not for the situations I get myself into.:)
You will have so much more fun with 4/WD, Then you can bury all 4 wheels instead of just 2. Don't ask how I know that or how many times it has "Happened".
When you get your 4/WD, get a back hoe and FEL, most of the time 1 or the other will pull or push you out. Might add a winch if your area has something to tie off too.
NOTHING IS MORE DANGEROUS THAN SINCERE IGNORANCE
/ Show us your Best Stuck #32
It is an interesting idea. As others have said before in regards to that video; getting hit by that log when things go wrong, or flipping the tractor over backwards, could create a tragedy. I would err on the side of caution, and get another machine and a long cable.
Not every idea is a good one.
/ Show us your Best Stuck #33
I came across this picture the other night online. Not mine and don't know who it is but........I would say they are stuck.
/ Show us your Best Stuck #34
Been in this axact situation with a deere 450 lgp. Actually pulled it out with my old 2640. We hooked the chain to the outer ear of the blade and let the tractor dig down with the rear tires to anchor it. Then rotated the blade side to side to work it out.
/ Show us your Best Stuck #35
Had to truck in a bigger excavator to dig this one out.
/ Show us your Best Stuck #36
Woodbridge Equipment Parts, based in Mississauga Canada is the distributor for TrackGrip steel cleats. The TrackGrip attachment can be installed on all machines with track widths ranging from 12 to 36 inches. The “easy-fit” TrackGrip bars can be installed or removed on site within approximately twenty minutes by an operator. Models are available for steel track excvators ranging from 6 ton upwards; enquiries on 1800-263-2309 and sales@woodbridgeeqquipment.com.
/ Show us your Best Stuck #37
do this in reverse gear and all is fine :)
/ Show us your Best Stuck #38
Here is 2 of mine
/ Show us your Best Stuck #39
Just one to many passes. :(
Needed little extra tug out.
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Vermeer RTX 250 Trencher  (A62679)
Vermeer RTX 250...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
