Should I buy this truck?
   / Should I buy this truck? #21
The day of the owner operator (single or a few trucks) operation is about gone. Been replaced by fleet owners (like my buddy) that own many units and hire drivers to operate them as employees.
I started out as an OO but ended up as a company driver, driving for an employer and not having to deal with all of the grief associated with being an OO. Weekly pay checks, good benefits and retirement far outweigh the 'joy of being an OO in my view.
Having said that, I do owm a Western Star long nose conventional with a 3406 Cat and an 18 speed as well as a 42 foot Timpte hopper bottom grain trailer and I do haul grain to the local evelators for local farners but it's more of a hobby than a job and I do it because I like to do it and not because I have to. Hard to get the smell of diesel smoke and the fun of running a big rig out of your karma when you do it for decades.
Just local stuff and while I hold a Class A CDL with all endorsements but Haz-Mat, I don't have a valid DOT physical as I don't need one to run Intrastate. Don't keep a log book either. Knowing the Federal DOT however, that will probably change as well.
   / Should I buy this truck? #22
I’ve used Passport twice and very satisfactory but I had a car to pickup in Florida and Passport was weeks out for pickup…
The seller said they had a husband and wife team coming to pick up another car destination California so I asked if there was room for one more…
The husband and wife team was 40% less and happy to pickup a second car with similar destination…
   / Should I buy this truck? #23
So if that Sterling is $20k I think you should. 👍
I like the camo also. It'll partially match your IH and several other colors. 😉
   / Should I buy this truck? #24
Bigger heavier parts would make them heavier duty, too. I think the oil capacity on the 4000 is much greater. Also handles up to 800HP.
Actually, if you compare the size between a 3k and a 4k, oil capacity is about the same.
As 5030 said maintenance is everything. Most of the failures I have seen is cooler failures.
Early models had a C3 pressure switch that would fail. Allison has a recall out on it but that has ended.
Good looking truck though. I like the camouflage myself. It's different and stands out
   / Should I buy this truck? #25
I see a lot of Volvo tractors…
After yellow freight closed down and auctioned their assets you can buy these Volvos cheap. And mine is 405 hp with jakes which is twice the power of most single axel trucks with DT 466s or c7 cats.
   / Should I buy this truck? #27
Sorry but I know Allison's. I can build all 6 lines they produce.
The 3k and 4k don't have an oil pan per say. If you have to pull the control mod "pan" for some reason, the valve body comes out with it. Be sure and unhook the harness from the block.pre gens have a whip harness and gen 4's have a short tower that the trucks harness plugs into. It will have a white tower in it, that's your oil level sending unit. They fail.
You can drain the oil but if you pul the control mod, it still holds about a gallon. Your gonna get dirty.
Easy transmissions to work on if you know what your doing.
From Allison website:
Power capacity:
“3000 Series™ transmissions can accommodate engines with power ratings ranging from 210 to 450 horsepower (157-336 kW) and torque capacities up to 1,250 lb-ft (1,695 N·m). These transmissions can support a GVW of 98,100 lbs. (44,500 kg).”
“The 4000 Series™ is ideal for heavy-duty vehicles that require substantial power and torque. It can accommodate engines with power ratings ranging from 380 to 800 horsepower (283-597 kW) and torque capacities up to 2,360 lb-ft (3,200 N·m).”
So the 4000 is clearly a heavier-duty automatic. It can handle almost twice as much horsepower and torque.
Fluid capacity:
In terms of fluid capacity, the 4000 series holds a LOT more fluid. Here’s the transmission fluid capacity of both:
Table 1, Lubricant Refill Capacities, Allison 3000 and 4000 Family Transmissions​
Lubricant Refill Capacities, Allison 3000 and 4000 Family Transmissions1
Family Sump Size Capacity : qt (L)
30004 Inch19 (18)
2 Inch17 (16)
40004 Inch39 (37)
2 Inch31 (30)23
  1. Quantities listed are approximate. Add listed amount of fluid, then perform a "hot check" and add fluid as needed. Do not overfill.
So the 4000 series holds up to twice as much fluid as the 3000 series.
Theres a guy from my area with a 3000 series allison with 900,000 miles on it. Original. Changed the fluid one time.
Damn....they were at one time. :-(
Bout the last Last thing I’m worried about in a truck is “pretty”. Now if its a woman, sure, I want pretty.
All I want is a truck that works and don’t cost a fortune.
I think those rims will polish-up ;)
After yellow freight closed down and auctioned their assets you can buy these Volvos cheap. And mine is 405 hp with jakes which is twice the power of most single axel trucks with DT 466s or c7 cats. View attachment 3492886
You overweight on your rear tractor axle?
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
Pallet Fees (A50775)
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
