short vs long 3PT arms on BX2200
/ short vs long 3PT arms on BX2200 #1
Anonymous Poster
Epic Contributor
I've read here that some implements don't fit on a BX2200 due to short 3PT arms and that some of you have
changed to older model arms that were longer.
If I'm buying a new 2200, should I try to get those longer arms right off the bat, and size my implements
accordingly?
My assumption is longer arms won't lift as much, since they are at a disadvantage.
Ideas Please as I'm getting ready to order the unit. THANKS.
There is only one set of Cat I arms available. We have not had any problem hooking up most 3-pt Cat I implements. If there is a problem because the implement pins are too wide, you can usually reverse the pins (outward to inward). We sell a Land Pride PHD especially built for the BX types and it comes with pins pointing both directions. Hope this helps.
</font><font color="blue" class="small">( I've read here that some implements don't fit on a BX2200 due to short 3PT arms and that some of you have
changed to older model arms that were longer. )</font>
I don't recall reading that in the last three months. I do remember some people talking about the top link length being an issue and the PTO shaft length being an issue.
Maybe I missed the one about the arms? /forums/images/graemlins/confused.gif
11' CONTAINER (A60432)
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
2001 Freightliner MB55 Bus (A59230)
2001 Freightliner...
