Shifting problems
/ Shifting problems #1
Jamassey
Trenton tx
Mitsubishi mte2000d
I just replaced the clutch, pressure plate, TOB on my mte2000d. All worked great for about 5hrs, now it's hard to shift with the Rpms high, have to throttle it down so it won't grind. Is this just break in or do I have issues. Have not adjusted yet.
/ Shifting problems #2
Check the pedal adjustment. I had similar problem when I changed my clutch. Putting the pedal pre-load into spec fixed the problem.
/ Shifting problems
I've adjusted in and out and still have the problem, any other suggestions would be great.
/ Shifting problems
Tried again adjusting from one end to the other and it worked this time. Thanks skylarkguy
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
New/Unused CFG Industrial MX12RX Mini Excavator (A65583)
New/Unused CFG...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
BUSHHOG RDTH84 - 7' FINISH MOWER (A64276)
BUSHHOG RDTH84 -...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
