Shifting problems
/ Shifting problems #1
Jamassey
Trenton tx
Mitsubishi mte2000d
I just replaced the clutch, pressure plate, TOB on my mte2000d. All worked great for about 5hrs, now it's hard to shift with the Rpms high, have to throttle it down so it won't grind. Is this just break in or do I have issues. Have not adjusted yet.
/ Shifting problems #2
Check the pedal adjustment. I had similar problem when I changed my clutch. Putting the pedal pre-load into spec fixed the problem.
/ Shifting problems
I've adjusted in and out and still have the problem, any other suggestions would be great.
/ Shifting problems
Tried again adjusting from one end to the other and it worked this time. Thanks skylarkguy
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
New/Unused Electric Winch (A65583)
New/Unused...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
72" JCT TILLER (A62613)
72" JCT TILLER...
Kubota SVL 75-2 (A64126)
Kubota SVL 75-2...
