Shifting problems
   / Shifting problems #1
Jamassey
Trenton tx
Mitsubishi mte2000d
I just replaced the clutch, pressure plate, TOB on my mte2000d. All worked great for about 5hrs, now it's hard to shift with the Rpms high, have to throttle it down so it won't grind. Is this just break in or do I have issues. Have not adjusted yet.
   / Shifting problems #2
Check the pedal adjustment. I had similar problem when I changed my clutch. Putting the pedal pre-load into spec fixed the problem.
   / Shifting problems
I've adjusted in and out and still have the problem, any other suggestions would be great.
   / Shifting problems
Tried again adjusting from one end to the other and it worked this time. Thanks skylarkguy
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
