Shifting on a J.D. 770
   / Shifting on a J.D. 770 #11
If you have a dual stage clutch, you must press the pedal all the way down to disengage. With a dual stage clutch, the first half of pedal travel disengages the PTO, the second half disengages the transmission.
I tend to slip up once and a while by either not coming to a full stop or not fully depressing the clutch.
   / Shifting on a J.D. 770 #12
My dual stage clutch engages the PTO first off the floor, then engages the drive wheels as you reach the upper end of the pedal travel.
Sean
   / Shifting on a J.D. 770 #13
Sean
Mine too, that way the implement keeps running full speed while you ease out the clutch to begin travel
   / Shifting on a J.D. 770 #14
You guys are correct. I stated it backwards.
Hmm - I do know that if I don't clutch all the way before going from a forward gear to reverse, I get a grind. But that doesn't make sense. Hmmm.
23" X 27" ROLLING METAL CART (A58374)
23" X 27" ROLLING...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
2018 Ford F-350 (A55973)
2018 Ford F-350...
Year: 2018 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 67,012 Plate: Body Type: 4 (A56858)
Year: 2018 Make...
