Shifting on a J.D. 770
   / Shifting on a J.D. 770 #11
If you have a dual stage clutch, you must press the pedal all the way down to disengage. With a dual stage clutch, the first half of pedal travel disengages the PTO, the second half disengages the transmission.
I tend to slip up once and a while by either not coming to a full stop or not fully depressing the clutch.
   / Shifting on a J.D. 770 #12
My dual stage clutch engages the PTO first off the floor, then engages the drive wheels as you reach the upper end of the pedal travel.
Sean
   / Shifting on a J.D. 770 #13
Sean
Mine too, that way the implement keeps running full speed while you ease out the clutch to begin travel
   / Shifting on a J.D. 770 #14
You guys are correct. I stated it backwards.
Hmm - I do know that if I don't clutch all the way before going from a forward gear to reverse, I get a grind. But that doesn't make sense. Hmmm.
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 14ft...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
Lehmann Hydratrol Hollow Spindle Engine Lathe 21 x 144 (A59213)
Lehmann Hydratrol...
2004 Sterling Acterra Cab and Chassis S/A Truck (A56858)
2004 Sterling...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
