Shifting on a J.D. 770
   / Shifting on a J.D. 770 #11
If you have a dual stage clutch, you must press the pedal all the way down to disengage. With a dual stage clutch, the first half of pedal travel disengages the PTO, the second half disengages the transmission.
I tend to slip up once and a while by either not coming to a full stop or not fully depressing the clutch.
   / Shifting on a J.D. 770 #12
My dual stage clutch engages the PTO first off the floor, then engages the drive wheels as you reach the upper end of the pedal travel.
Sean
   / Shifting on a J.D. 770 #13
Sean
Mine too, that way the implement keeps running full speed while you ease out the clutch to begin travel
   / Shifting on a J.D. 770 #14
You guys are correct. I stated it backwards.
Hmm - I do know that if I don't clutch all the way before going from a forward gear to reverse, I get a grind. But that doesn't make sense. Hmmm.
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Massey Ferguson 1759 (A57148)
Massey Ferguson...
JMR 96in Forklift Safety Basket (A56857)
JMR 96in Forklift...
VINTAGE JOHNSON MOTOR (A58374)
VINTAGE JOHNSON...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
