shift adjustment procedure.
/ shift adjustment procedure. #1
YukonKing
Whitehorse Yukon Canada
2021 L2501 FEL
Hi all,
I have a JM254 with shuttle.
Does anyone have the shift adjust procedure. I have a hard time going into gear.
/ shift adjustment procedure. #2
There are 2- adjustments, under the tractor,there is no procedure other than to lengthen or shorten the cable.,or make the linkage move the arm in or out more (looks like a turnbuckle close to the back under the tractor) Make sure the linkage is not binding at the rear where it pivots ,sometimes it will bind and cause the shifting to be hard.
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Can you tell me, is the transmission shifted in one area of the case or are both pivots shifting one in and one out?
/ shift adjustment procedure. #4
/ shift adjustment procedure. #5
One. The mechanical sequence of the shuttle is lever->floorboard->pivot point->cable->pivot point->shuttle housing->shift. Forward or reverse selection is the only function this lever provides. The actual ground speed is selected with the second (gear shift) lever. It is a direct mechanical connection to the transmission housing (no cable).
//greg//
UNUSED FUTURE MINI EXCAVATOR 31" ROCK BUCKET (A65055)
UNUSED FUTURE MINI...
Big John Semi Trailer (A65640)
Big John Semi...
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
UNUSED RAYTREE RMD882 HYD DIGGER BACKHOE (A65055)
UNUSED RAYTREE...
L6060 Kubota For Sale
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
