Shibaura SD2043 Hyd problem HELP
/ Shibaura SD2043 Hyd problem HELP #1
HeyDannie
I was brush hogging the other day and noticed fluid spewing out from under the hood. The hydraulic pump had a crack from the mounting base to end base. I replaced the pump with a new pump different design but same mounting and it worked for about an hour and has started leaking at the seam. I have a Koyker lift in the system also. Question can anyone tell me why this is doing this and what to do about it .Please Its getting expensive
/ Shibaura SD2043 Hyd problem HELP #2
Is it leaking at the gasket ?
Try some permatex gasket maker or sealer on it and let it sit overnight before using it. Also did you clean your hydraulic filter screen in the pump & replace the external filter?
Ernie
Thanks and yes I cleaned the filter and it had fine pieces of metal on the magnets on the filter. The pumps seems to work part time now. It worked great before the first pump cracked. Don't know anything about hydraulics but do you have to bleed them are could their be a part time blockage?
/ Shibaura SD2043 Hyd problem HELP #4
Does it have an outside spin on-off filter ?
/ Shibaura SD2043 Hyd problem HELP #5
Check Hydraulic Fluid Level. Did you add fluid? Make sure you did not mix 2 different types of hydraulic fluid. Sounds as it is foaming and would cause the fluid to aireate and when it does... the hydraulics will not work. I bet if you drain the fluid and put in the correct fluid this will correct your problem.
Jim
/ Shibaura SD2043 Hyd problem HELP #6
The 2043 does not have a spin on filter; filter is in a canister on top of the pump. There is a bolt on top of the filter you remove to prime the pump. Fill it to the top. Make sure your tranny is full of fluid also. Sounds like low fluid to me.
Buck
No just the one filter before it enters the pump.. Thanks
Clean fluid from Atwoods no mix, and when I check it its clear no foam.
The pump is new the one I replaced had cracked. I did prime the pump before starting and had the fluid level at the proper level. Thanks Buck...Dannie
/ Shibaura SD2043 Hyd problem HELP #10
Dannie, call me and lets get to the bottom of this.
509-521-1507 evenings are best
Buck
2022 EZ-GO ELITE...
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
Manure Spreader (A65640)
Manure Spreader...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
