Shibaura: front axle fluid
/ Shibaura: front axle fluid #1
alaskatomd
Can any one tell me the type of gear oil and capacity i should be putting in the front axle housing and diff of my 4X4 P17F Shibaura?
thanks,
Tom
/ Shibaura: front axle fluid #2
Suggest you drain the fluid out, eye balling the amount. 3 quarts? 5 quarts?
Assuming it was full to begin, or nearly so.
This will tell you the capacity. It is sometimes difficult to hit with exact precision the capacities as stated in some spec sheets or manuals for a variety of reasons. Then begin to refill. Re-fill until the "line" is hit. Different tractors have differing methods of marking "full".
4 wheel, and if in a warmer climate, 80w90 or even udt is fine, but I like the flow rate of a semi-synthetic gear lube. 75w90 semi synthetics is affordable and readily available, even at Wally's. Best wishes.
thanks for the input guys.
Ya, i think i will use semi-syn gear oil. even though i keep my tractor garaged in the winter it gets mighty cold up here.
later.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
PORTA POTTY (A67714)
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2015 CHEVROLET CAPRICE POLICE VEHICLE (A66091)
2015 CHEVROLET...
2020 KENWORTH T880 TRI-AXLE HYDROVAC TRK (A67714)
2020 KENWORTH T880...
