Shibaura: front axle fluid
   / Shibaura: front axle fluid #1
alaskatomd
Can any one tell me the type of gear oil and capacity i should be putting in the front axle housing and diff of my 4X4 P17F Shibaura?
thanks,
Tom
   / Shibaura: front axle fluid #2
Suggest you drain the fluid out, eye balling the amount. 3 quarts? 5 quarts?
Assuming it was full to begin, or nearly so.
This will tell you the capacity. It is sometimes difficult to hit with exact precision the capacities as stated in some spec sheets or manuals for a variety of reasons. Then begin to refill. Re-fill until the "line" is hit. Different tractors have differing methods of marking "full".
4 wheel, and if in a warmer climate, 80w90 or even udt is fine, but I like the flow rate of a semi-synthetic gear lube. 75w90 semi synthetics is affordable and readily available, even at Wally's. Best wishes.
thanks for the input guys.
Ya, i think i will use semi-syn gear oil. even though i keep my tractor garaged in the winter it gets mighty cold up here.
later.
2019 Vengeance Rogue Toy Hauler Camper (A50514)
2019 Vengeance...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2013 Freightliner M2 106 Altec AA755 55FT Bucket Truck (A50323)
2013 Freightliner...
2024 John Deere 6110M (A50120)
2024 John Deere...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
