SHHHHHHHHHHHHHHHHHHHHHHHH
/ SHHHHHHHHHHHHHHHHHHHHHHHH #81
Well, the 2210 is gone from the Configurator... No new one, yet!!!
/ SHHHHHHHHHHHHHHHHHHHHHHHH #82
Has anyone noticed the number of hits on this thread? I guess we all get excited about new equipment! /forums/images/graemlins/grin.gif
sure has been popular,,
almost as popular as talk about cabs on 3020 series eh?
/forums/images/graemlins/wink.gif
/ SHHHHHHHHHHHHHHHHHHHHHHHH #85
</font><font color="blue" class="small">( One of the biggest selling points for me IS the Deere 'plastic'. The color is molded in, it takes abuse like nobody's business.... Deere doesn't use it top cut costs.)</font>
10-4,
Guys, "plastic" is space age and state of the art. Absolutely top drawer. You know, in 40 years when the metal has long since lost its paint and has holes rusted through, the plastic will still be fresh, and, it is getting better all the time.
Is that hard to swallow?
Just ask a tree hugger! /forums/images/graemlins/grin.gif They'll tell you it will be here forever! (uhmmm, I think that's the point!)
GOT IT!
Pricing as follows
pretty basic setups... with turf or R-4,,, that's it for now.
all with Dual SCV standard..
$10,750!!!! with R-4
$10,726 with Turfs
no big options available from factory yet.. basics,, quick hitch, wheel weights.. most stuff from 2210 will fit it looks
/forums/images/graemlins/cool.gif
oh,,, immediate availability they say too!!
/ SHHHHHHHHHHHHHHHHHHHHHHHH #88
C/forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gifL!!
It's on Configurator!!
/ SHHHHHHHHHHHHHHHHHHHHHHHH #89
This post offers nothing but a smile over how everyone has had too-much-fun-by-half in this thread. While I'm not in the market for this model, it's been a joy to read TBNers share a huge amount of info of a positive and informative nature!
Dutch, you're the daddy of this! Thanks!
And thanks to all who have helped me without knowing it...
/ SHHHHHHHHHHHHHHHHHHHHHHHH #90
<font color="red">"Yes sloped may look great and give better view of the loader (same thing could be accomplished with a wide enough bucket and sloped arms" </font>
Well it appears that JD is listening. I was at the local dealer today looking at the 2210. The dealer said that the 210 FL is being replaced by the 200CX. The new FL has a 53" bucket and sloped arms.
/ SHHHHHHHHHHHHHHHHHHHHHHHH #91
Thats true, My 2210 with the 200cx has sloped arms . I'm not sure how wide the bucket is though.
Jim
/ SHHHHHHHHHHHHHHHHHHHHHHHH #92
Hmmm, Another good thing on the configurator (sp?) is that there are now brush guards available for the warning lights! I'd like to get those for my 2210.
/ SHHHHHHHHHHHHHHHHHHHHHHHH #93
Standard Features
2305 4-Wheel Drive Tractor
ENGINE:
Yanmar 3 Cylinder Liquid Cooled Diesel Engine
Horsepower @ 3000 RPM: Gross 24.0 (17.9 kW)* Net 23.5 (17.5 kW)*
PTO 18 (13.4 kW) HST*
*Manufacturer's Est.
68 Cu. In. Displacement (1.115 L)
Indirect Fuel Injection
Auto Bleed Fuel System
Glow Plug Cold Starting Aid
Anti-Freeze
Dry Type Air Cleaner With Safety Element
Fully Enclosed Engine and Muffler With Horizontal Exhaust
5.5 Gallon Fuel Tank Capacity (21 L)
Hand Throttle
Key Engine Shut Off
TRANSMISSION:
Hydrostatic Transmission:Infinitely Variable - 2 Speed Transaxle
2-Pedal Foot Operated Speed and Direction Control
Differential Lock
FRONT/REAR AXLE:
Flanged Rear Axle
Spur Gear Final Drive
4WD
STEERING AND BRAKES:
Hydrostatic Power Steering
Wheel Brakes
Park Brake
Wet Disk Brakes
HYDRAULICS:
Open Center Hydraulic System
Hydraulic Pump - Total Flow 5.2 GPM (19.7 L/min) with Filter
Working Pressure (1987 PSI)
Dual Mid SCV Standard
PTO:
Mid PTO Standard Equipment
Independent Mid and Rear PTO
540-RPM Rear PTO
Hydraulic PTO Clutch
PTO Brake
Separate or Simultaneous Operation of Mid and Rear PTO
Flip Up PTO Shield
ROCKSHAFT, 3-PT. HITCH, AND DRAWBAR:
Rockshaft Limited Category 1, 3-Pt. Hitch
Rate of Drop/Stop Valve
Drawbar
INSTRUMENTATION:
Electric Fuel Gauge
Tachometer/Hour Meter
Oil Pressure Indicator Light
Coolant Temperature Light
Alternator Indicator Light
Flashing Warning Light Indicator
ELECTRICAL:
12-Volt Electrical System
Wet Battery With 500 Cold Cranking Amps
20 Amp Alternator
Key Ignition Starter With Neutral Start Switch
LIGHTS:
Two Front Halogen Head Lights
Two Flashing Warning Lights
One Tail Light
OPERATOR PROTECTIVE STRUCTURE:
Fixed ROPS (Roll-Over Protective Structure)
Deluxe Cushion Seat With Seat Belt
Operator Presence System
MISCELLANEOUS:
SMV Emblem
Front Weight Bracket
Tilt-Up Hood
Cupholder - Left Console
Mower Deck Height Adjustment
BASE MACHINE (4WD):
Engage on the go 4WD
TIRES
Two - Steel Wheels With 26x12-12 4PR (R4) Rear Industrial Tires
Two - Steel Wheels With 18x8.50-10 4PR (R4) Front Industrial Tires
-or-
Two - Steel Wheels With 18X8.50-10 4PR (R3) Front Turf Tire
Two - Steel Wheels With 26X12-12 4PR (R3) Rear Turf Tire
/ SHHHHHHHHHHHHHHHHHHHHHHHH #95
The brochure says is uses 1.6 gallons/hours at full load. This seems high to me.
/ SHHHHHHHHHHHHHHHHHHHHHHHH #96
Full load is very heavily loaded, but that still seems high....
/ SHHHHHHHHHHHHHHHHHHHHHHHH #97
When looking at this link to the 2305 info., I can't help but think the picture of the front in the "attachments for field ..." section looks like the model number is 2320. Plus the front lights look different than the 2305. Is this a peek of the new CUT series?
/ SHHHHHHHHHHHHHHHHHHHHHHHH #98
Good catch. I think your right. Looks like a 2320 to me. Also look for a reference to the 2000 Twenty Series under the iMatch Quick Hitch section. I think we can safely say that a they are coming, can't wait to see them. Personally I hope the adapt a mower hook-up system common to the 2305, the one they use now on those units is awkward. When they come out, I think Deere will have a really nice, complete line-up.
/ SHHHHHHHHHHHHHHHHHHHHHHHH #99
Look on page 17 rear working lights , look below photo shown on 3000 TWENTY series.
/ SHHHHHHHHHHHHHHHHHHHHHHHH #100
I just got a quote from my dealer in PA.
2305, 200cx FEL, 62c MMM, hood guard, ballast box....
$14,200. Claimed to be available Aug. 19th. This is, however, without the independent MMM lift. I'm told that it will be available in the fall.
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
LOT LOCATIONS (A59914)
2012 Ford Escape SUV (A61574)
2012 Ford Escape...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
