sheer pin Q
/ sheer pin Q #1
TC29-dude
Banned
Saint Francis Mountains - Missouri
2001 NH TC29
I broke the sheer pin on the old brush hog I picked up when I got my TC29.
I went to the local hardware store and they gave me grade 3 bolts to use, are they too hard? The hardware store guy told me that they were the softest made but I have just found out that that's not true.(from reading here at TBN!) I don't want to use to hard a bolt and screw something else up.
Thanks!
/ sheer pin Q #2
Are you sure they're grade 3 (two marks on the heads)? Most hardware stores carry grade 2, 5, and 8. Most shear pins are grade 2 bolts (no marks on the heads) and if in fact you have grade 2s I wouldn't worry about it...
/ sheer pin Q #3
The marks are little bars. If you are not familiar with them, this website shows the markings and grades quite nicely.
/ sheer pin Q #4
I've never been clear about this. I always assumed a shear bolt was specifically designed to break at a certain stress level. In other words, the only place you'd use one was in a place that you wanted it to break. But is a shear bolt really just a lower grade of 'regular' bolt?
/ sheer pin Q #6
So technically, it isn't a shear bolt until you put it in a hole that requires a shear bolt.:D
I'm being silly of course, but at the same time I don't want to walk into the local TSC and ask for a shear bolt and then get directed to the regular bolts and tell the adolescent sales clerk, 'no, I said I wanted a shear bolt'.
I guess I'd rather look stoopid here than in the tractor store.:D
/ sheer pin Q
Thanks for the replies!
My bolts must be grade 2, they have no marking on them other than 3 initials...HKT. I assume that is the manufacturer as that doesn't match up to any of examples show on SnowRiges nifty chart.
I think it's interesting that you can't tell the dif between grade 1 and 2...It seems like that would be a good thing to me.
/ sheer pin Q #9
I did a little research on the web. And even though this might be a technicality with no practical application here, there are, in fact, pins and bolts designed specifically as shear pins and shear bolts. Many of them are actually grooved at a designed break point. Most of them appear to be used in heavy machinery.
Also, when I asked recently, it was recommended that I use grade 3 shear bolts for a 14" two bottom plow. Does that sound right?
/ sheer pin Q #10
ToadHill said:
I was told years ago that sheer bolts are grade 5's.
It must be according to what implement you have? I've noticed almost 100% of the people recommend a grade 2 for shear bolts. The only implement I have that uses a shear bolt came with a package of 5 grade 8.8 bolts with self locking nuts. 8.8 is a metric that's almost a perfect match for a grade 5 SAE.
/ sheer pin Q #11
I think the manufacturers went to grade 2 bolts, when the realized they could save some money, and their customers wouldn't have to stock a supply of specialized shear pins. I used to have to replace shear pins back in the 70s when I was a GI. Now I replace bolts. The bolts are easier.
/ sheer pin Q #12
We used to give a helper a few boxes of bolts and a hack saw to make "shear bolts" for snow blowers when they were "bad".:D Shear bolts are implement specific and there is no standard, but there is nothing wrong with using a "weaker" bolt as long as ya don't mind changing them more often. :cool:
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
(2) Electric Motors (A64127)
(2) Electric...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
PREVIEW DATES AND TIMES (A65583)
PREVIEW DATES AND...
1999 New Holland 688 Round Baler (A63688)
1999 New Holland...
