shear pin vs. slip clutch
/ shear pin vs. slip clutch #21
John, right now I can't think of the proper words to describe the way that driveline is made, but the answer to your question is, nope, it won't come apart if you shear the bolt. You don't need to worry about that.
Bird
/ shear pin vs. slip clutch #22
The first indication I got that I had sheared the shear pin was "I thought I just mowed that strip", then looked back and saw through the hole in the deck that the blade wasn't turning. /w3tcompact/icons/smile.gif
/ shear pin vs. slip clutch #23
I wonder if these ID's are the same for inch and metric bolts. Back in my motorcycle mechanic days, SAE was AST fine or course in inches. It would make sense for SAE to now have a metric standard. The PTO shaft for my snow blower takes a metric shear bolt. Guess I'll take a look at the bolt heads.
/ shear pin vs. slip clutch #24
If they're made in the U.S., they have the same markings, according to the information I've got.
Mark
/ shear pin vs. slip clutch #25
John, probably what you're looking at isn't the shear bolt. The shear bolt isn't technically part of the PTO shaft, but part of the gear box input shaft or output shaft, depending on how it's designed. So all of the PTO shaft components remain completely intact when the shear bolt breaks because the two pieces of the gearbox input or output shaft are held together by their mounting points.
Mark
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2007 Land Rover Range Rover Sport (A59231)
2007 Land Rover...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
