shear pin vs. slip clutch
   / shear pin vs. slip clutch #21
John, right now I can't think of the proper words to describe the way that driveline is made, but the answer to your question is, nope, it won't come apart if you shear the bolt. You don't need to worry about that.
Bird
   / shear pin vs. slip clutch #22
The first indication I got that I had sheared the shear pin was "I thought I just mowed that strip", then looked back and saw through the hole in the deck that the blade wasn't turning. /w3tcompact/icons/smile.gif
   / shear pin vs. slip clutch #23
I wonder if these ID's are the same for inch and metric bolts. Back in my motorcycle mechanic days, SAE was AST fine or course in inches. It would make sense for SAE to now have a metric standard. The PTO shaft for my snow blower takes a metric shear bolt. Guess I'll take a look at the bolt heads.
   / shear pin vs. slip clutch #24
If they're made in the U.S., they have the same markings, according to the information I've got.
Mark
   / shear pin vs. slip clutch #25
John, probably what you're looking at isn't the shear bolt. The shear bolt isn't technically part of the PTO shaft, but part of the gear box input shaft or output shaft, depending on how it's designed. So all of the PTO shaft components remain completely intact when the shear bolt breaks because the two pieces of the gearbox input or output shaft are held together by their mounting points.
Mark
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
