Shear pin strength
/ Shear pin strength #22
On my snowblower I drilled a dozen holes in the cover shield over the auger drive shaft. This is where I bolt 6 spare PTO shear bolts and 6 spare auger shaft shear bolts.
No hunting or trying to remember where I put that little bag of bolts.
May sound crazy but if you saw all the stuff and hiding places in my garage you would understand my logic.
/ Shear pin strength #23
On my snowblower I drilled a dozen holes in the cover shield over one of the auger drive shafts. This is where I bolt 6 spare PTO shear bolts and 6 spare auger shaft shear bolts.
My L4200 has a little mini-trunk that is right behind the seat between the rear fenders. Took me 6 years of ownership before I found that it opened up and there was a cubbie-hole in there. I bet most tractors have the something similar - Kubotas anyway. That's where I keep my extra shear bolts, along with a couple of spare 3pt hitch locking pins.
/ Shear pin strength #24
...... because they are all too retarded to run the register systems. ............
As much as I hate Home Depot, I don't go to Lowes anymore - they are far worse than HD when it comes to raw stupidity of employees (and they are more expensive than HD).
JayC
Well I found that at both of them, the cashier could not tell me the size of a standard sht of plywood. In inches or feet!
I didn't have the heart to complain to management.
/ Shear pin strength #25
My Martin Meteor 51" blower used the same size shear bolts. After I used the five bolts that I got with the unit I drilled out the PTO housing to accept standard 1/4 -20 bolts. ( .015 larger than 6mm) I now buy them bulk by the pound at TSC and use the grade 5.
Last year I went through about a dozen and so far this year ..... none yet.
/ Shear pin strength #26
I bought my metric PTO bolts M6X40-8.8 at TSC. Did not break the bank but if I can avoid metric I will. I am going to drill out my rig.
Thanks for the tip!
/ Shear pin strength #27
Yep, drilled mine out too. Now the blower takes just one size shear pin, instead of two. PTO takes 1.5 inch length, the auger 1 inch, but I can get the 1.5 inch bolt in there if I "Use the Force".
I HAVE used grade 5 on the PTO, but I try not to. Grade 2 works nice, and hopefully shears quicker if needed.
/ Shear pin strength #28
ok very interesting. I have a kubota b2789 rear pto blower. it uses a m10 x 1.25 8.8 part # 70060-02609 my question is if i also dill out the hole for 1/4 bolt which strength do i use? I'm waiting now for a delivery of shear bolts from my local Kubota place. I like to make life easy and not pay 3.50 for a shear pin. thanks:thumbsup:
/ Shear pin strength #29
Be aware that if your pin is now a 10mm then the actual size is now at least .393 which obviously greater than 1/4 (.250)
I would personally try a standard 3/8-16 bolt (.375 diam) and see how sloppy the fit is. You could go up in size to a 7/16 bolt (.437) but I would then worry that it would be too strong and defeat having a shear pin in place. And the grade 5 would be OK in the 3/8" diameter.
/ Shear pin strength #30
On my gravel driveway, at least until everything really froze solid, I was going through several shear bolts almost every time I used the blower. Even now when I try to clean up the street mess I manage to hit serious chunks of ice & shear a couple. I found this place: Bolt Depot - Nuts and Bolts, Screws and Fasteners online
to be a great source. they had the metric size / grades I needed and shipped very quickly. One hundred pairs each (bolt and captive nut with nylon insert) of 2 different shear bolts with shipping was under $40.
/ Shear pin strength #31
A pound, maybe 25-30 pieces, of 1/4-20 x 1.5 grade 2 bolts at TSC was like $2. Most of the time when it shears I can recover the nyloc nut and reuse it.
/ Shear pin strength #32
thanks, upon review, my book lists two differant shear pins. Goig by what u said ,i guess ineed the other one which is m6x40 grade 8. so now i will check that out because the other one is too big! thanks for the heads up!
/ Shear pin strength #34
My PTO uses an M8 (grade 6.6) bolt. When I got the blower, the PO had put in a std snowblower (5/16") shear pin. I went through a couple of those at $3.50 each, but couldn't (and still can't) find grade 6.6 metric bolts. I replaced it with a std 5/16" bolt. I can live with the extra 0.00246" space.
JayC
/ Shear pin strength #35
JayC
I believe 6.6 is equivalent to grade 2 in the SAE system, and grade 5 is very close to 8.8 in metric.
I've never seen 6.6 either, although I haven't looked for it specifically.
Sean
/ Shear pin strength #36
You might concider getting a slip clutch from agri supply This is my first year using it, and i have it set to slip before the shear pin breaks.. Its jammed a couple times and havent broken a pin yet (knock on wood).
/ Shear pin strength #37
I keep two cheapy, (read Harbor Freight) 7/16 wrenchs onboard and several 1/4" Gr/5 bolts, and nylock nuts. I find that torquing is the key! Tighten it too much,Bang, Tighten it too little, the 'slop' will shear it! Tightened just right, it will last for the season.........~S
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
Mini rock grapples (A61567)
Mini rock grapples...
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
159115 (A60430)
159115 (A60430)
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
