Shear pin strength
/ Shear pin strength #22
On my snowblower I drilled a dozen holes in the cover shield over the auger drive shaft. This is where I bolt 6 spare PTO shear bolts and 6 spare auger shaft shear bolts.
No hunting or trying to remember where I put that little bag of bolts.
May sound crazy but if you saw all the stuff and hiding places in my garage you would understand my logic.
/ Shear pin strength #23
On my snowblower I drilled a dozen holes in the cover shield over one of the auger drive shafts. This is where I bolt 6 spare PTO shear bolts and 6 spare auger shaft shear bolts.
My L4200 has a little mini-trunk that is right behind the seat between the rear fenders. Took me 6 years of ownership before I found that it opened up and there was a cubbie-hole in there. I bet most tractors have the something similar - Kubotas anyway. That's where I keep my extra shear bolts, along with a couple of spare 3pt hitch locking pins.
/ Shear pin strength #24
...... because they are all too retarded to run the register systems. ............
As much as I hate Home Depot, I don't go to Lowes anymore - they are far worse than HD when it comes to raw stupidity of employees (and they are more expensive than HD).
JayC
Well I found that at both of them, the cashier could not tell me the size of a standard sht of plywood. In inches or feet!
I didn't have the heart to complain to management.
/ Shear pin strength #25
My Martin Meteor 51" blower used the same size shear bolts. After I used the five bolts that I got with the unit I drilled out the PTO housing to accept standard 1/4 -20 bolts. ( .015 larger than 6mm) I now buy them bulk by the pound at TSC and use the grade 5.
Last year I went through about a dozen and so far this year ..... none yet.
/ Shear pin strength #26
I bought my metric PTO bolts M6X40-8.8 at TSC. Did not break the bank but if I can avoid metric I will. I am going to drill out my rig.
Thanks for the tip!
/ Shear pin strength #27
Yep, drilled mine out too. Now the blower takes just one size shear pin, instead of two. PTO takes 1.5 inch length, the auger 1 inch, but I can get the 1.5 inch bolt in there if I "Use the Force".
I HAVE used grade 5 on the PTO, but I try not to. Grade 2 works nice, and hopefully shears quicker if needed.
/ Shear pin strength #28
ok very interesting. I have a kubota b2789 rear pto blower. it uses a m10 x 1.25 8.8 part # 70060-02609 my question is if i also dill out the hole for 1/4 bolt which strength do i use? I'm waiting now for a delivery of shear bolts from my local Kubota place. I like to make life easy and not pay 3.50 for a shear pin. thanks:thumbsup:
/ Shear pin strength #29
Be aware that if your pin is now a 10mm then the actual size is now at least .393 which obviously greater than 1/4 (.250)
I would personally try a standard 3/8-16 bolt (.375 diam) and see how sloppy the fit is. You could go up in size to a 7/16 bolt (.437) but I would then worry that it would be too strong and defeat having a shear pin in place. And the grade 5 would be OK in the 3/8" diameter.
/ Shear pin strength #30
On my gravel driveway, at least until everything really froze solid, I was going through several shear bolts almost every time I used the blower. Even now when I try to clean up the street mess I manage to hit serious chunks of ice & shear a couple. I found this place: Bolt Depot - Nuts and Bolts, Screws and Fasteners online
to be a great source. they had the metric size / grades I needed and shipped very quickly. One hundred pairs each (bolt and captive nut with nylon insert) of 2 different shear bolts with shipping was under $40.
405 (A52706)
405 (A52706)
2015 Ford Fusion Sedan (A59231)
2015 Ford Fusion...
John Deere 5055E (A53317)
John Deere 5055E...
2014 Freightliner 105' Bucket Truck (A61307)
2014 Freightliner...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
