Shear pin misery... only thing left is adding a slip clutch?
   / Shear pin misery... only thing left is adding a slip clutch?
This is the cheap one you had shipped from China right? Part of the reason it was so cheap was that it shipped with a cheap PTO shaft.....
There is no doubt... which is why I'm not bitching... just searching. I knew there was a likelihood that there would be kinks. The question I had to ask beforehand was 'Am I willing to deal with them for the $ savings.'
I am willing, and even if I have to purchase the brand name PTO shaft, it will still be significantly less expensive than an Italian import, for me. I can buy a new gear box, bearings, hydraulic cylinders, and shaft for less than the Italian machine. I might have ended up wasting my money, but I don't think so. The quality looks pretty good. The weak spots are the PTO shaft (obviously) and the gear box which is on the small side.
I like to try things... I'm not afraid to fail should something go bad. I've never imported anything myself, before, and it wasn't that bad at all. It wasn't just the $... it was saving the $ while doing something new.
   / Shear pin misery... only thing left is adding a slip clutch? #42
I've never heard of a PTO engagement working that way, but that's not to say that it doesn't. For the life of me I can't imagine why a tractor would go through that sort of routine to engage a piece of equipment. Maybe some sort of idiot proofing.
But for goodness sake don't go wasting $1000 when you probably do not have a problem. If your tractor will let you engage at low RPM then just do it and enjoy your mower and the savings that went along with it. If it continues to break pins after that then do what you have to do.
My tractor is only 45 hp. It has a lever that electronically engages the PTO but you can do it incrementally. Even at idle speed if I just throw that lever my 6' rotary cutter will hop and shake all over the place. I cannot imagine dumping the PTO at anything above idle. Something would give.
   / Shear pin misery... only thing left is adding a slip clutch? #43
Guys guys... I can engage at a lower RPM. I see your point.
I did a very slow PTO engagement, and it worked, but it felt like I was going to break that pin the entire time. I just didn't have confidence that it would hold. After it began spinning, there wasn't an issue, but still in my head, I knew the shaft is undersized.
You seem hesitant to accept engaging the PTO at idle. Why not keep engaging PTO at idle, and if no more broken shear pins = problem solved. If after doing that multiple times and you keep breaking shear, then maybe you want to look into Plan B.
   / Shear pin misery... only thing left is adding a slip clutch? #44
Guys guys... I can engage at a lower RPM. I see your point. All I am saying is that according to the JD manual that comes with the machine, it says to throttle to PTO speed, then engage. I have an electric PTO clutch, and as soon as I engage it, the RPMs drop down. I don't think it is simply overcoming inertia via brute force (but I could be wrong). I think the tractor immediately throttles back then builds up. It happens when I have nothing on the shaft as well. I've just been doing what I grew up with and have always done and the manual corroborated my actions.
But... I am having a VERY hard time finding a long enough shaft to work. I did find one with a CV jnt and slip clutch... for $1070 + shipping. Probably $1200 to my door.... That's more than 50% of what I paid for the whole thing shipped to Cincinnati.
We have the same tractor. If you don't believe me, call your dealer and talk to the service department for the correct way to engage pto. Flat out, 100%, you are doing it WRONG. The manual doesn't say to do that, you are inferring it due to the way it's worded. If you can't engage at idle due to it killing the tractor, run the rpms up a little and then engage it. The tractor is dragging down because it's taking serious power to get things moving and what your doing is destroying your pto clutch. I've run equipment since I was 8 and most has been Deere. Nothing has every been engaged at full rpm.
Like I said, please call ANY dealership and they will tell you the correct way to engage pto
Brett
No, No.... I'm not hesitant to improve. I'm not going to argue the merits of idle PTO starts. It makes sense that this would take strain off the system. And certainly I was able to get the machine working from a slow start.
Perhaps, as you say, I just need to try it a while and see how it goes. If all I need is an idle PTO start to get this running, certainly, I'd rather do that than unnecessarily add to the cost.
I think I will give it a shot and try. If it still doesn't work then I will go the new shaft route.
   / Shear pin misery... only thing left is adding a slip clutch? #46
The thing of it is, we all just assumed that everyone knew to engage the PTO at or just above idle to lesson shock loads on equipment.
So much for assuming. . This is a practical lesson of what happens when an irresistible force meets an immovable object. Or pretty close to that. Something is going to break. There is a heck of a lot of power in that PTO shaft built up at PTO speed, but there is a heck of a lot of mass in the implement to get rolling instantaneously too. Is the PTO shaft and shear bolt too small? Yep sounds like it, but if you can do a soft start and get by with it, why not use it and enjoy the savings?
And it has been a lesson for me too. Never assume anything. I will shut up now.
   / Shear pin misery... only thing left is adding a slip clutch? #47
I think replacing the pto shaft with a larger one and continuing to engage it at full RPM may very likely destroy the gear box on the mower. Which you have pointed out several times looks fairly light weight. The shear pin is going to look like a very inexpensive and quick part to replace if you grenade the gearbox!
   / Shear pin misery... only thing left is adding a slip clutch? #48
Please don't go the new shaft route!! Listen to the unanimous chorus of your TBN guardian angels! Just learn to start the PTO at or more likely a few hundred RPM above idle. You'll soon learn what the lowest engine setting allows you to start reliably without stalling. Shaking a bit is par for the course.
   / Shear pin misery... only thing left is adding a slip clutch? #49
I'd be more concerned about the tractor's PTO guts. The other end of most PTO shafts have fine splines and nothing like the drive splines on the outside. The diameter is usually smaller too. Like I mentioned earlier, the OP should keep tractor parts in stock to change out the rear end. :cool:
   / Shear pin misery... only thing left is adding a slip clutch? #50
Yep. Most of what I've learned about 'tractoring' I learned from the collective wisdom here at TBN. No shame in that. The rest I learned by trial and error. The error parts can be expensive and dangerous.
The OP did the right thing by coming here and asking. If the advice works, great! If not, nothing lost really.
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
