Shear pin (bolt)
   / Shear pin (bolt) #1
Milbrand1951
Aiken, SC
John Deer 1000 series
On my JD 1023e tractor, the drive-line shield guard on the Frontier rotary cutter sits atop the shear pin which I need to change because it keeps breaking. I am probably not using the correct shear bolt which I plan on correcting. In the manual it says to bend back driveline shield cone. How do I do this? It is kind of awkward trying to tighten the bolt with the shield guard in the way. Would appreciate any help on this. Do I need to un-fasten the shield cone to do this? Surely someone out there has had to replace a shear bolt on a Frontier cutter.
   / Shear pin (bolt) #2
When these guards get in the way I modify or remove them.
larry
   / Shear pin (bolt) #3
larry
+1 Can you simply cut away a bit of the guard(I assume it's the wide part over the universal joint) with tin snips? I had to do that for my snowblower.
   / Shear pin (bolt)
Yeah, thanks. Several other people advised me to do the same thing.
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
