shear bolts
/ shear bolts #1
barticus73
Clarksburg, Pa(Between Indiana and Saltsburg Pa)
Cub Cadet 7272,Farmall 544
I feel kinda stupid but here goes... When you go to TSC to get shear bolts for the TSC PHD and I also need them for a NH S68 baler, do you just get the right size and grade of bolt (grade 2) or are there specific bolts called shear bolts? I was at TSC last night and all I could find was grade 2 bolts but nowhere did it say 'shear bolt'.
Thanx
/ shear bolts #2
Just get grade 2 bolts, nuts, and lock washers in the correct size, (you'll probably lose the nut and washer). I just bought 3 from TSC. Asked the clerk where the shear bolts were, he just went to grade 2 bolts and got them.
/ shear bolts #3
Ditto what normde2001 said and I'll further emphasize the locking nuts. My wife was 'hoggin the other day and she came in nearly in tears thinking she broke the tractor. She described what I thought was a broken shear bolt. I went out to find that it hadn't broken but the non-locking nut had come off and the bolt had worked itself out. The parts were all lying on the deck so I just reassembled it and got her on her way again. Bought some locking nuts later that day /w3tcompact/icons/smile.gif
/ shear bolts #4
grade 2 is what to use for shear bolts - just get the right size. There are no specific "shear bolts" per sey, just the right grade.
/ shear bolts #6
barticus73,
TSC does have shear bolts in a package of 5 for mowers on the wall at the one I go to. If memory serves they were about $4-5. Much cheaper to by the bolts in bulk. They charge $1.19 per # for grade 2 hardware.
If you use a bolt that is longer where the shoulder is exposed you don't need the lock washer. All that you have to do is jam the nut into the shoulder. You will probably loose the nut when the bolt shears anyway.
You need to make sure that a longer bolt won't contact or interfere with anything else. Before all the paranoid safety people go crazy; this is only a suggestion not a recommendation. I only do this when I don't have the lock washers or correct lenght bolts available.
Don
Bobcat A770 (A60462)
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 Chevrolet...
John Deere 5525 (A60462)
John Deere 5525...
