shear bolt on brush hog?
/ shear bolt on brush hog?
Thanks... Is there a particular brand or place I should look for one? Easy to install? picture of one by any chance?
Thanks,
Ryan
/ shear bolt on brush hog? #22
Hmmm, I ordered my brushhog with one and it is safely, I hope, stored in a shipping container about 41 miles away. It doesn't look like much and mounts right onto the gearbox side of the PTO shaft.
/ shear bolt on brush hog? #23
Here's a picture of one that replaces the shear pin. also availible with spline connections in and out for tractor end of implement shaft. Every dealer has them.
http://cgi.ebay.com/PTO-slip-clutch-conversion-rotary-cutter-smooth-NEW_W0QQitemZ7573702028QQcategoryZ48712QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You adjust the exposed bolts for desired slippage. if it's slipping too much you should be able to feel heat build up. There should be no slippage most of the time unless something solid is hit or your feed rate is too high ie traveling too fast for the mower. This can happen it you have too much HP for the mower. It's possible to set the clutch so tight that the gearbox would fail first, not the way to go.
/ shear bolt on brush hog? #24
That looks just like mine even the color but the price is out of line, especially with shipping. These are the items where it pays to have a relationship with your dealer since his cost is likely low.
When they are delivered it is safe to assume that the clutch is too tight and the instructions are good to help you adjust it.
/ shear bolt on brush hog? #25
Man, at that price ($117++) you can buy an awful lot of grade 2 bolts.
/ shear bolt on brush hog? #26
Haven't some of those slip clutches frozen up in those mowers and damaged the gear box? I have only used mowers with shear bolts over 30 years of mowing and never damaged a gear box yet. The shear bolt mowers are a lot cheaper and you usually don't break many shear bolts as long as you start the mower at low RPMs which you probably should do with all mowers whether you use a slip clutch or not.
/ shear bolt on brush hog? #27
</font><font color="blue" class="small">( I have shot rocks the size of baby heads for hundreds of feet. )</font>
Good info in this thread, but I can't get the image of baby head rocks out of my head!
Dennis
Thank you again for all the info, I will check further into the slip clutch, sounds like a good deal, I will check with the dealer also....
/ shear bolt on brush hog? #29
Sorry if the image of the little heads flying and tumbling is disturbing. It makes me laugh every time I think of it. I do a good bit of competitive off-road dirt bike riding in the woods and when a trail ahead is described as being full of baby heads then you know it will be rough.
I have two little girls with the youngest at 3 months. You have to enjoy these things.
/ shear bolt on brush hog? #30
Didn't mean to imply I didn't enjoy the image, here's a smile-thing /forums/images/graemlins/smile.gif
Dirt bikers have to be able to laugh at a lot, eating all that mud and dirt.
Dennis
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2022 EZ-GO ELITE...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
