   / Share Pics of People Hauling or Towing Something Wrong #19,002
Managed to land on his tires... I'd call it a win!
I had a dump truck nearly turn itself over in my own back yard, several hundred feet from the nearest asphalt, and behind an old stone wall with no direct path for retrieval. Idiot forgot to unlock his tailgate before raising bed, and only stopped because I started waiving and yelling when I saw his front tires leaving the ground. Not saying driver experience had anything to do with that video, but it seems some businesses will put any untrained fool in dump trucks.
   / Share Pics of People Hauling or Towing Something Wrong #19,003
Not upping you but these are the one I used, I would think they are better since its rubber to rubber and not steal to rubber but I used metal screw to secure them and lots of them snap off after some time I would think they where too tight and the vibration cause them to snap.
Yeah, those are definitely better. I use those on battery cables and audio stuff, as well as hoses and tubing.
   / Share Pics of People Hauling or Towing Something Wrong #19,004
I added reflectors on my log splitter, but no lights. My small (4x6) trailer lights gave me grief from day one until I finally replaced the regular push-in bulb type with LED's. They work EVERY time now.
   / Share Pics of People Hauling or Towing Something Wrong #19,005
What do you think went wrong with yours? Usually, the only trouble I ever see with trailer wiring is corrosion at the connection points, on trailers left outdoors, or UV breakdown of the wiring insulation if they're left in the sun. Both of those failures take years, not days!
The cheap Chinesium "wire" that comes with many trailer light kits will self destruct within a year or so.
   / Share Pics of People Hauling or Towing Something Wrong #19,006
mine didn't take two weeks, I completely rewired my trailer and tested the lights then parked it. Two weeks later I hooked it up to make a run to the lumber yard but the lights didn't work so I pulled it up to the shop and was looking for something I did wrong but the only thing I did wrong was not reading the package to see where it was made because the ground wire was rotten I broke it with my hands all the way up to the plug.
   / Share Pics of People Hauling or Towing Something Wrong #19,007
Isn't that one of those small scale RC trucks?
Good call. The way the camera so easily runs down the hill as the action is underway. And the preposterous loading of "boulders" up above the dump bed. It's not a real truck.
   / Share Pics of People Hauling or Towing Something Wrong #19,008
...the ground wire was rotten...
I used to to have a heck of a problem with my trailer lights. Not sure if it's because I have a tilt trailer or not but I finally ended up running a ground wire straight to the lights. Tied it into where it bolts up. Have not had an issue since and I think the lights are brighter, too...
   / Share Pics of People Hauling or Towing Something Wrong #19,009
Looks real to me and: Google Lens
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
Giyi 72" Grapple (A57149)
Giyi 72" Grapple...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56436)
Midwestern...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
