   / Share Pics of People Hauling or Towing Something Wrong #15,181
Montreal Quebec has lots of bridges marked as low on major roadways, and no warnings. Or directions to get around them.
Many drivers stop at these things and then a local trucker comes by and says "go ahead". "Lots of room". Or, "you'll fit, just go slow
and don't hit a bump that may bounce your trailer too much".
Then they usually go through first to prove it.
You'd think it would be easier to replace the signs than have a truck stop in the middle of the road.
(I could go on and on about trucking in Montreal).
   / Share Pics of People Hauling or Towing Something Wrong #15,184
So, 15 ft is 4.57m. Those extra 7 cm really made the difference.
   / Share Pics of People Hauling or Towing Something Wrong #15,185
The trainer said:
"Bad things happen at the scale house ... travel the back roads"
   / Share Pics of People Hauling or Towing Something Wrong #15,188
Looks like it was over height and took out the stabilizer links between the trusses.
Definitely had nothing to do with the "Weight Limit 6 Tons" / No Trucks
Or maybe he figured he's not driving a box van that didn't apply to him
   / Share Pics of People Hauling or Towing Something Wrong #15,190
^ 15 feet and still jammed tight?!? That doesn't seem right.
European setup, 2 axle COE with a 3 axle trailer. In Europe standard trailers are not higher than 4 meter. In the UK apparently overweight/height/width permits are obtained as easy as brown bread, so maybe this trailer is a UK special thats higher.
Although the sign is definately wrong, this trailer is by no means taller than 4.5m
Asphalt paving can be a ***** though, when i went to school there was an overpass under which they repaved the surface. The added 10cm caused a lot of truck jams, that had been passing under there for a decade.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New Landhonor Heavy Duty Plate Compactor (A59000)
New Landhonor...
PITTSBURG 2R CULTIVATOR W/ ALL FEET (A52708)
PITTSBURG 2R...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2007 CHEVROLET KODIAK C4500 (A58214)
2007 CHEVROLET...
