   / Share Pics of People Hauling or Towing Something Wrong #15,181
Montreal Quebec has lots of bridges marked as low on major roadways, and no warnings. Or directions to get around them.
Many drivers stop at these things and then a local trucker comes by and says "go ahead". "Lots of room". Or, "you'll fit, just go slow
and don't hit a bump that may bounce your trailer too much".
Then they usually go through first to prove it.
You'd think it would be easier to replace the signs than have a truck stop in the middle of the road.
(I could go on and on about trucking in Montreal).
   / Share Pics of People Hauling or Towing Something Wrong #15,184
So, 15 ft is 4.57m. Those extra 7 cm really made the difference.
   / Share Pics of People Hauling or Towing Something Wrong #15,185
The trainer said:
"Bad things happen at the scale house ... travel the back roads"
   / Share Pics of People Hauling or Towing Something Wrong #15,188
Looks like it was over height and took out the stabilizer links between the trusses.
Definitely had nothing to do with the "Weight Limit 6 Tons" / No Trucks
Or maybe he figured he's not driving a box van that didn't apply to him
   / Share Pics of People Hauling or Towing Something Wrong #15,190
^ 15 feet and still jammed tight?!? That doesn't seem right.
European setup, 2 axle COE with a 3 axle trailer. In Europe standard trailers are not higher than 4 meter. In the UK apparently overweight/height/width permits are obtained as easy as brown bread, so maybe this trailer is a UK special thats higher.
Although the sign is definately wrong, this trailer is by no means taller than 4.5m
Asphalt paving can be a ***** though, when i went to school there was an overpass under which they repaved the surface. The added 10cm caused a lot of truck jams, that had been passing under there for a decade.
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
2015 GENIE S-60 MANLIFT (A58214)
2015 GENIE S-60...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
