Shaft Conversion for PTO Generator
/ Shaft Conversion for PTO Generator #21
You will need to get a frequency meter to get it to the right RPM. Here is a cheap frequency meter.
/ Shaft Conversion for PTO Generator #22
get a step up gearbox like many pto gensets use..
with only 150$ in it.. consider that a deal on the head only and get rid of the rub goldberg pulley deathtrap..
/ Shaft Conversion for PTO Generator #23
This is what the calculator says you have now:
To get 3600 RPM on the 2.5 pulley with a 540 PTO, you need a large diameter of 16.6...
I would prefer a gearbox instead.
The pulleys measure as follows:
Large = 7" (roughly 175mm)
Small = 2.5" (roughly 60mm)
That's the issue right? If the PTO generator calls for 3600rpm's and the tractor is a rear 540, I need a larger ratio between the two pulleys. It seems to make sense why the volts are only reading 100 or so.
Any brilliant ideas? Like, sell it and buy a different one? I only have $150 into it and it's a Winco. Old but apparently working.
Thanks for all the quick responses
/ Shaft Conversion for PTO Generator #24
Theres your problem alright. No single stage upgearing of ~ 7:1 is even possible with a 7" major pulley using a V belt. Even if possible it would slip bigtime. You could do it with a small HTD gearbelt and appropriate pulleys. That would be the cleanest mod to the existing setup - not cheap in proportion to your orig cost. You could buy a stepup gearbox for it - even more not cheap.
larry
This has been a major education session. And I appreciate it.
Just did a bunch of reading on stepup gearboxes. Didn't know what one was until a few hours ago.
I'll be bouncing all this off a friend tomorrow, who knows his stuff. I'll likely pick up a different PTO generator, one that is setup for 540
Thanks again for all the quick help
dp
/ Shaft Conversion for PTO Generator #26
If you sell it, tell the buyer that as it is, it needs about 1285 RPM input to turn 3600 RPM.
/ Shaft Conversion for PTO Generator #27
/ Shaft Conversion for PTO Generator #28
as cheap as that job was ( 150? ).. the addition of a few hundred dollar step up gear box would yeild a working pto gen still int he 'very cheap' range..
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
JOHN DEERE 3038E TRACTOR (A64277)
JOHN DEERE 3038E...
2012 C&M TRAILER 16' ENCLOSED CARGO TRAILER (A65643)
2012 C&M TRAILER...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
