Shady Rest Progress
/ Shady Rest Progress #21
Shade,
Nice. I haven't seen a newly poured foundation before.
/ Shady Rest Progress #22
Looking good Shade. It must be a lot drier where you are, no ruts /w3tcompact/icons/grin.gif Where is the soil from the hole? Any idea when you'll start framing? That's when things really take off /w3tcompact/icons/smile.gif
The soil dug out for the basement is spread out around the basement so that the cement trucks could go around to pour all sides. They did not pump the concrete. The dirt will also be used to build up around the front sides of the house since we poured a little over 3' out of the ground. There will also be more dirt from the back side where the walkout is to come around front. I'm trying to keep the house & garage "high & dry".
The "I" joists should be delivered this afternoon for the main floor. They may start that initial phase of framing tomorrow. /w3tcompact/icons/smile.gif The drain plumbing was laid in the basement today. I may have another picture tonight.
Shady Rest has floor...
The engineered I-joists & subfloor were installed today...
View from the front of wife & daughter "cuttin a rug" on our new floor /w3tcompact/icons/laugh.gif /w3tcompact/icons/smile.gif /w3tcompact/icons/eyes.gif
Re: Shady Rest has floor...
This view from near the road. The cement trucks have really packed in the #2 & #3 gravel driveway. I think that it will be very solid /w3tcompact/icons/eyes.gif -I hope.
This view from the TreeHouse deck. /w3tcompact/icons/grin.gif
The walkout area is to the right...
/ Shady Rest Progress #28
Looking good Shade! Sure is fun isn't it? Obviously your wife and daughter are enjoying it as well. Walls today? When is your estimated completion? Keep the pics coming /w3tcompact/icons/smile.gif
/ Shady Rest Progress #29
Wow! looks good. I cant wate till I get to that point with mine. I should be going to contract in the next week. YEHAA!!!
/ Shady Rest Progress #30
Hey guys, its a good thing we are all building this year. That way we have homes for our tractors to sleep in.
Shady Rest has walls...
Here's some walls... /w3tcompact/icons/smile.gif
Completion should be the end of June. Things are going along really well now. The 1st plumbing inspection was today & the basement floor should be poured on Monday. On Tuesday, the primary electric line will be buried.
/ Shady Rest Progress #32
Re: Shady Rest has walls...
Shade
<font color=blue>the basement floor should be poured on Monday</font color=blue>
Why don't they do this before the floor and walls go on??
I see why houses are so dear over there. That basement etc. is some major work. We just level the site, pour some very small edge beams (1'x1') and pour a 4" slab. Done !!!!
Cheers
Neil, <font color=blue>Why don't they do this before the floor and walls go on??
<font color=black>The builder would have poured the basement floor 1st if the plumbing inspection of drains could have been completed sooner. Either way, he says that much of the concrete will have to be handled through the walkout basement doors. He doesn't want to loose a day in order to save 2 hours. The builder started framing while waiting for the inspector. This small contractor with 3 full time crew members, 2 of which are his sons, do all of the work (and they don't mess around) except excavation, concrete, and HVAC. The GC is a certified electrictian while his oldest son is a certified plumber.
<font color=blue>I see why houses are so dear over there. That basement etc. is some major work
<font color=black>Our basement will be important living space /w3tcompact/icons/smile.gif > family/rec room (15'X28'), utility room, bathroom, & storage room. There will be french doors out of the basement onto a patio overlooking the valley/revine to the north.
/ Shady Rest Progress #34
Looks like everything going well building your new home since you started.
Tomorrow we turn the clocks ahead which should help pounding nails in the evening...oooh do I remeber those days. /w3tcompact/icons/wink.gif
/ Shady Rest Progress #35
Wow, isn't it amazing how fast the framing goes! And how fun it is to begin visualizing the spaces you will eventually occupy. Thanks for the pics /w3tcompact/icons/smile.gif
/ Shady Rest Progress #36
neil,some concrete guys like to pour the basement floor after the joists are on to keep the walls plumb ,if the concrete is still a little green. also the excavator likes the floor poured before they backfill the foundation so the bottom of the walls don't blow out. i've seen it happen. it ain't pretty......tgello
/ Shady Rest Progress #37
How do you get drainage out of the basement??
Pumps??
/ Shady Rest Progress #38
Neil
Usually, a foundation is built in an area where the water table is normally below the cellar level. A perimeter drain is built around the outside of the footing. An interior drain system connected to a sump may be installed under the basement floor slab. Water that gets into the interior is pumped out by the sump pump. If the water table is high it also complicates the issue of building a septic system. An area with a high water table will not " perk '.
RonL
As suggested, the basement is located on a high point of the land above the water table with actually about 40" of poured wall above that in order to keep things high & dry. We will use fill dirt (like RobS) to build up to the garage floor level. There is a 4" perforated drainpipe outside the footer & 3" drains on the inside of the footers (under the floor) -both leading out away from the house. We put plastic sheeting down for the basement floor to be poured on to help keep water OUT (along with Radon). We have heard Pros & Cons about this practice. As said earlier, we are going to use some of the basement as finished living space, so keeping things dry is important.
<font color=red>Here's a picture of the basement.
<font color=black>The builder says that many pour the floor right away with poured walls but not ever with block & that backfill should never be done until the framing is in place to hold the walls.
/ Shady Rest Progress #40
OK I get the outside water drainage bit, but how do you get your sewer and grey water out of the basement?
I assume it drains to a sump and is then pumped out.
Going back to en earlier post, this basement arrangement is to get your footings below the frost line - Correct??
$ - Wow $$$$$$
2025 28in Forks and Frame Mini Excavator Attachment (A66734)
2025 28in Forks...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2008 THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
2008 THE MACHINE...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2012 CATERPILLAR 303.5E CR EXCAVTOR (A65056)
2012 CATERPILLAR...
2018 Lodal EVO MAG-20 20yd Side Loader Garbage Truck (A66736)
2018 Lodal EVO...
